Driveshaft hanger bearing question
Old 11-17-2018, 09:51 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
So I am replacing the driveshaft hanger bearing. I can't find anything to show me which way goes towards the back. Does anyone know? Also does this new retainer replace the old one? Let me know which picture is the right one. Thanks.
Old 11-18-2018, 01:49 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Ruckin69
So I am replacing the 2 piece driveshaft center support bearing. I can't find anything to show me which way goes towards the back. Does anyone know? Also does this new retainer replace the old one? Let me know which picture is the right one.
Old 11-18-2018, 01:53 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Thanks. I've seen this diagram but I still can't tell which way it goes from the picture. Seems like rubber faces the rear, correct? What about the retainer?
Old 11-21-2018, 04:49 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
So I installed the new center bearing on but the original locking ring (in the picture) will not stay snug on the shaft. I put the carrier on like picture #1. I was wondering if it is necessary to put that lock ring on with this new center bearing or was it used for an older design. I also have this spacer?? that came with the carrier and there wasn't one on originally ( I don't believe). I believe the center bearing is seated as far back as it can but am curious on if or how these press on tight. Thanks for the input.
Old 11-21-2018, 08:20 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
I think the driveshaft needs to be able to move to-and-fro as the rear suspension articulates?
Old 11-21-2018, 09:07 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
I understand that but this retaining ring that was on the old center bearing is not pressing into the driveshaft. Do I need that on the new center bearing?
Old 11-21-2018, 10:33 PM
meangreen92
Darn. I'd look at my truck for you, but I won't be able to access it until Saturday or Sunday. Hopefully someone posts up a definitive answer before then.
Old 11-22-2018, 08:03 AM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Thanks! No rush...
tracyclifton
03-24-2015 08:32 AM
daddylee100
12-12-2014 06:31 PM
Funke1
17
09-30-2014 02:28 PM
BigMikeUGA
12-31-2011 07:38 PM
trentmw
02-16-2006 04:38 PM
Quick Reply: Driveshaft hanger bearing question
