Sealing the axle flange
Yeah, I think I'm gonna try no gasket. Only thing I've used gasket maker in place of gasket has been a diff cover, I used and so far hasn't leaked a bit. Any preference in which RTV to use?
Yeah, I think I'm gonna try no gasket. Only thing I've used gasket maker in place of gasket has been a diff cover, I used Permatex Ultra Grey and so far hasn't leaked a bit. Any preference in which RTV to use?
I checked and my local parts store has Fel-Pro 55328 which is steel. What sealer would you use on these? From some of the comments, you don't need sealant, which would be nice since I have to take axles out to service brakes.
I'm not sure I follow. The back (inner) side of the hub has a wheel seal. The axle flange is what seals the outer side of the hub and stops the axle/diff gear oil from leaking out.
I have a set, the reduction of rear-end noise was remarkable. The axle race wear sneaks up on you and the increase in noise is not immediately noticeable.
I would add one caveat to installing the repair bearing/seal assemblies: There is the possibility that the O-ring seal between the bearing/seal assembly and the axle tube may be compromised during installation resulting in oil seepage. A thorough cleaning of the seam between the assembly and axle tube then filling that seam with black silicon sealer will prevent any unexpected leakage.
The flange gasket goes between the end of the axle and the brake backing plate. That’s what I thought you were referring to.
Apologies if if I confused the issue.
are we talking the 9”? I have been. There is an axle seal that gets pressed in, the. The axle shaft with bearing slides in.
rhw
02-01-2019 10:25 PM
'78F250351m
18
08-16-2013 07:46 AM
Schuyles
03-30-2012 05:47 AM
PChiders
10-06-2005 07:27 PM
