E4OD ?
Old 11-17-2018, 03:43 PM
JRB64's Avatar
JRB64
JRB64 is offline
E4OD ?
Ok, So I was told that the E4OD that would bolt to my 460 is very specific but is there any other E4OD's that will bolt to my 460 like the Diesel version of the Transmission? I only ask because I need a 2 wheel drive version for the Over Drive Upgrade I am doing to my 1975 Highboy Frame. Thanks in advance for any help I can get with this.
Old 11-17-2018, 05:38 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
The diesel version has it's own bellhousing pattern of Navistar.It's not a match to the big block ford.You can use a 4wd big block version by installing a transfer case. You'll need a shortened driveshaft of course but you'll gain a set of low range gears to use.Even for a 2wd truck this is still handy for backing up trailers,driving slow on back roads,bird hunting and such.
Old 11-18-2018, 09:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
That is correct. End of story.
therigwelder
04-03-2014 08:29 AM
THE KING
01-03-2008 11:17 AM
hokeyson
04-20-2003 10:10 PM
jkiser96
03-22-2002 07:38 PM
Quick Reply: E4OD ?
