Getting Ready to Order, Questions/Opinions
Looking to get some opinions on people that have driven these more than me.
Looking to order a 19 F250 CBSB SRW Blue Jeans/ Two Tone with Stone Gray
Lariat Ultimate
Tow Tech
FX4
20" Bright machine cast Aluminum wheels(Worth it?)
Front/Rear Slash Guards and Wheel Well Liners
Spray in Bed Liner
BLIS
Quad-Beam Headlights
LED Clearance Lights
Extended Running Boards
Adaptive Cruise Control
Garage Door opener
Upfitter Switches
We won't be towing much more than 6-8000 pounds so don't need anything DRW or anything.
This will be a daily driver so I thought the ride on the 250 would be better than the 350. WOuld you suggest a 350? Are there any big errors or changes you would suggest? This will be my first new SD and planning on keeping it for a while. So wan't to make sure I make the right decisions.
Lariat Ultimate
Tow Tech
FX4
Spray in Bed Liner
BLIS
Garage Door opener
Upfitter Switches
Lariat Ultimate
Tow Tech
FX4
Spray in Bed Liner
BLIS
Garage Door opener
Upfitter Switches
Lariat Ultimate
Tow Tech
FX4
Spray in Bed Liner
BLIS
Garage Door opener
Upfitter Switches
Any input on the original post would be desired though.
I don't have my 2019 F-350 Lariat CCLB 4x4 6.7L yet, and I've never owned a Ford Super Duty, or a Ford for that matter. My last truck and tow vehicle was a 5.7L Tundra. However, I did quite a bit of research before ordering my truck in early October. Here's some ideas based on that research and many ideas and opinions expressed on this forum. I went for the 350 over the 250. It is clear that there isn't much difference between the two excepting primarily suspension. They have the same engine, same body, and same interior. Obviously, the 350 has a higher GVWR; mine is the 11,500lb version. I don't have to worry about registration costs because I hail from Texas where my annual registration fee is $155. I asked them if a 350 is considered a commercial vehicle; they replied, "It's ONLY A TRUCK." I like that attitude.
I didn't get the FX4 package for three reasons: 1) I specifically did NOT want the Hill Descent Assist because, from all I've been able to figure out, it is simply a computer operating your brakes while going down a steep hill. I can operate my own brakes, thank you. And if I want to go slow down a steep hill, I'll throw it in 4x4 Low 1. In that gear, I won't be touching my brakes too much. 2) I didn't care for the "tuned shocks". I have no personal experience with them, but most of the people who have expressed opinions aren't too happy. Instead of the FX4 package, I included skid plates. I decided that I'd use the approximate $300 that I saved on the omission of the package to put a set of Biltstine 5100 shocks on my rig which I'll do at the first tire change if not sooner. And lastly, I really didn't need the FX4 Decal.
I also didn't opt for much BLING, such as Blind Spot Information or the High Capacity Trailer Tow Package. You should be aware that the BLIS doesn't work while towing a 5th Wheel or a trailer longer than 33', neither of which I do. But at 63 years-old, I can still turn my head and use my mirrors to identify anyone lurking in my so-called blind spot. I pretty much get everything in a 350 that I would have gotten in a HCTTP, ergo I went with the 350. I did not opt for the LED Quad Beam Headlights for something like $1000 or the so-called Moon Roof for something like $1,400; neither of these lights my fire.
I went for the Lariat Ultimate Package because it included the Power Telescoping Steering Column with MEMORY (the Value Package gives you power mirrors and driver's seat with MEMORY) and the tailgate step. The two other things that you get are Rain Sensing Wipers and Automatic High Beam controls which were both added to the Lariat Ultimate Package in 2019.
Another bling-thing I went for was Adaptive Steering for $920 (I got my truck at invoice which is this price). I was not going to get it at first, and I didn't include it in my original build. A few days after setting the order, I realized that it was a Platinum F-250 with Adapative Steering that I had driven right before ordering, and I'd driven it on city streets at slow speeds. It hit me how comfortable and effortless it was to turn at 90 degree corners. I called my dealer, and thankfully I could adjust the order to include AS.
In lieu of the HCTTP, I went for the 350 and the Trailer Tow Camera System. In the 350, I get everything that's in the HCTTP on a 250 relative to the suspension and the rear end: a fourth leaf spring, larger ring gear in the differential, and the upgraded steering gear, stabilizer and front springs. I'm pretty sure that my truck is coming with 5600lb front springs, the middle weight rating. The 250 comes with 5200lb front springs. I read on this forum that one longtime Super Duty owner said a 350 drives much better than an upgraded 250. I can't speak to this from personal experience; I took his word for it.
I opted out of the Chrome Package. I didn't want to pay over $1,000 for a bunch of chrome. I also was going with the Power Running Boards that were $920, so I didn't need the 6" Angular Chrome Step Bars. I went with the Power Boards because they sit 2" lower than fixed boards. This is for my 5'3" wife. After she tried both, the decision was made.
I also went with the engine block heater and wheel well liners front and rear. I added a fifth wheel prep package even though I don't tow a fifth wheel; it was for resale. In retrospect, I probably wasted the $460. I included the upfitter switches for no real good reason. I may actually use five of them, two for backup lights on each of the truck camper shell and the back of my trailer and a fifth for a pump on an auxiliary fuel tank. I went for the long bed to get the 48 gallon tank, but I might add a 50-gallon auxiliary tank in the bed to double my range since we are full time RVers and occasionally do long-haul driving.
I opted out of the all-weather floor mats and the mud flaps. I'm going to put Husky Floor Liners and Husky Muddog Mud Flaps in and on the rig. The Muddogs are less than half of the price of Gatorbacks which are Ford accessories but cost about $470. The floor liners are slightly more expensive than the Ford liners, but I think they're made of better material.
Lastly, I went with 18" Bright Polished Cast Aluminum Wheels and A/T tires which will be Goodyear Kevlars. I was set on 20" tires, but people on this forum persuaded me to go with the 18's. I measured the height of 18" A/Ts and 20" A/Ss and was surprised that they were the same. So I went with the 18s. I since have discovered that a lot of people remove their new 20" Bright Polished Cast Aluminum Wheels with Michelin A/T-2 tires almost immediately upon taking delivery of their trucks, putting on something else. I have found many of these for sale on Craigslist for $1000-$1500 with the TPMS sensors included. So I'm planning on buying a set as backup. This package of wheels and tires retails for around $3,500. I can always use an extra set of wheels and tires. Why not?
There you go. You asked.
Last edited by Hjabernathy; 11-18-2018 at 09:38 AM. Reason: To copy it to my word processing program
If sticking with the 250, I'd add the camper package.. adds a leaf and swaybar. I myself did a ccsb lariat gasser F350. I honestly can say it's smooth as silk on the highway but you know your in a 350. The 6.2 with the 4.30s is more then enough for me. My current trailer is only about 8k dry. I opted out of the spray in liner as I feel linex is 10xs better and a few bucks cheaper. I skipped the fx4 and ordered skids seperate. I did however get the 5er package just in case we upgrade.
I don't have my 2019 F-350 Lariat CCLB 4x4 6.7L yet, and I've never owned a Ford Super Duty, or a Ford for that matter. My last truck and tow vehicle was a 5.7L Tundra. However, I did quite a bit of research before ordering my truck in early October. Here's some ideas based on that research and many ideas and opinions expressed on this forum. I went for the 350 over the 250. It is clear that there isn't much difference between the two excepting primarily suspension. They have the same engine, same body, and same interior. Obviously, the 350 has a higher GCWR; mine is the 11,500lb version. I don't have to worry about registration costs because I hail from Texas where my annual registration fee is $155. I asked them if a 350 is considered a commercial vehicle; they replied, "It's ONLY A TRUCK." I like that attitude.
In lieu of the HCTTP, I went for the 350 and the Trailer Tow Camera System. In the 350, I get everything that's in the HCTTP on a 250 relative to the suspension and the rear end: a fourth leaf spring, larger ring gear in the differential, and the steering gear, stabilizer and front springs. I'm pretty sure that my truck is coming with 5600lb front springs, the middle weight rating. The 250 comes with 5200lb front springs. I read on this forum that one longtime Super Duty owner said a 350 drives much better than an upgraded 250. I can't speak to this from personal experience; I took his word for it.
We decided to go with the diesel for the pulling power, the TORQUE, in a 2019 Super Duty. We expect the fuel costs to be roughly a wash between the gasser and diesel. To explain, we expect to get 30% better MPG while paying about 25% more for diesel or regular gas. However, we get a HUGE increase in pulling power and load capacity with our F-350 over our Tundra.
GO DIESEL.
