F250 dually conversion ?
Old 11-17-2018, 07:46 AM
Arsoncop's Avatar
Arsoncop
Arsoncop is offline
My project is a 1973 F250 4x4 highboy that is a retired fire/rescue truck. It was delivered from the factory as a cab/chassis and the fire/rescue company added a fiberglass utility body to it. It has dual rear wheels i know ford did not produce a F250 with dual rear wheels so they were added must likely by the upfitters. It apprears the wheel studs were replaced with longer ones. My question is, can i add a hub to the front dana 44 axle to have the same wheels all the way around? And if so which hubs will work? It has drum brakes. Currently the front rims do not match the rear rims.
Old 11-17-2018, 06:58 PM
somethingclever's Avatar
somethingclever
somethingclever is offline
No dually hubs for d44 but you can convert to d60 and dually hubs.
Old 11-17-2018, 07:29 PM
Arsoncop's Avatar
Arsoncop
Arsoncop is offline
So it doesn't look like i am going to be able to place the same wheels on the front as the rear
Old 11-18-2018, 01:29 AM
buckin69bronco's Avatar
buckin69bronco
buckin69bronco is offline
You can put spacers on the front hubs to get the effect of a dually hub. Typically it takes 3” spacers to do this. In the early 2000’s and maybe late 90’s Dodge uses factory spacers added to their hubs on their dual rear axle trucks. Sometimes you can find these cheep in junk yards.
Old 11-18-2018, 08:14 AM
Arsoncop's Avatar
Arsoncop
Arsoncop is offline
The dodge bolt pattern will match up ?
Old 11-19-2018, 02:53 PM
speedfreak78's Avatar
speedfreak78
speedfreak78 is offline
Yeah dodge stayed with the 8 x 6.5 bolt pattern, I think they still run it. Those Dodge spacers are around 4" wide and designed for 9/16" wheel studs. Our trucks have 1/2" studs, the stock lug nuts won't hold the bigger holes correctly. You'll need to swap your trucks front hubs to bigger studs to mount it. There's a 9/16 stud that swaps right in, but I don't know the part number. Maybe try a 95-97 f350 stud? I know those are 9/16. Then you'll need to swap the wheel mounting studs on the spacer back to 1/2" studs to fit your stock wheels. Or you could buy some 3" spacers that work with the stock hub studs and wheels.
Old 11-13-2022, 08:34 PM
4x4busguy's Avatar
4x4busguy
4x4busguy is offline
1st Gear
Dana 44 to dully
go to Torqueking.com
Old 11-14-2022, 10:04 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
shakedownshorty
01-04-2015 08:39 AM
jmcboots
02-03-2003 12:31 AM
jmcboots
12-31-2002 04:31 PM
jmcboots
09-26-2002 07:23 AM
Quick Reply: F250 dually conversion ?
