Truck with on the floor shifter won't go into 4x4,
Hi guys, I have an 09' f-150 xl with a manual on the floor 4x4 lever. When i put it in 4hi on the move or even parked and put it in 4wheel and move forward it just makes a Grinding, clunking noise and vibrates the truck. And sometimes I can't even get it to engage going in reverse before putting it in forward gear.
Your front hubs are VACUUM controlled.. When the motor is running, the VACUUM pulls the piston and DISENGAGES the front hubs.. When you go into 4 x 4, you break vacuum and the pistons are suppose to move inward and engage the hub. You have o-rings and seals to help things slide smoothly...... I would guess you have partly STUCK pistons.. see if you can narrow down the location of the grinding... front end, left or right.......... you can probably test them with the front wheels off the ground.. idle the motor and the wheels should turn by hand..... put in 4 x 4 and they should LOCK .. see if they grind when turned by hand.
