Can anyone tell me what color blue this is on this truck. I am thinking of painting my daughters 75 this color just flipping the blue and white. Thanks in advance.
The crease in the bottom of the door is one give away. It signifies the door has side impact beam which is '94 up.
Unless of course, the door is not original.
The third brake light is another 94 up item on the trucks.
I’ll buy that but why not a ‘96?
Nice color combination. I can see why you’d want to paint the ‘75 like that.
Brad, What identifies that as a 94/95? Was that color only available those two years?
94+ has the 3rd brake light
95- has the moulding behind the rear tire
9/95+ has the small crease at the bottom of the door(I cannot see clear enough if it has the crease)
You have good eyes if you can see the crease
There looks to be a faint line. More so on the left corner, but maybe that is a gouge?
After clearing 50 your eyes can start doing weird things
What about the tailgate panel?
Didn't the last couple years of OBS trucks have a Ford oval on the driver's side -vs- the Ford script on the right?
Maybe I'm thinking of the HD trucks in 97.
Thanks for the info. I pulled up the paint chart and was showing her the color and beside the truck was another one that was Bahama Blue Metallic that has decided to go with.
Be sure to share your before and after pics of your truck for us!
I will. Have to replace the exhaust manifold on th drivers side then it’s off to the body shop. Here’s the before. Have all new body panels for it. Getting them welded in. The red is going to be blue and the white is going to be done in Oxford White.
