TPMS on dually
I installed braided extensions, which have a bracket the you pop rivet to the center cap. I posted pics back when I did it, I think 2014.
My post
My post
Can you suggest a dependable brand and also the length needed for ONLY the i nside tires. The outsides are NOT a problem.
Thanks again
https://www.amazon.com/dp/B004VRO19Y/ref=cm_sw_r_em_apa_QCe7BbQWY3YG4
and etrailer
https://www.etrailer.com/Tire-Inflation-and-Repair/Wheel-Masters/WM80012.html
I have not seen just the inners. I have a link saved on Amazon, cause I gave a new dually. Still deciding if I put these sensors on when I have them built in.
and etrailer
and etrailer
Looks like they changed how the end attaches to the outside tire on them now. I like the way you're are riveted to center hub cap.
I left on vacation w my fw, and towed 350 miles. I had a TPMS alarm about 200 miles in, but all was ok. The next morning as I was hooking up, I noticed the right rear center cap and the outside extension and TPMS sensor were gone! The inside extension was still there, w sensor and the little bracket.
The full metal valve stem on the outer wheel was sheared off, exposing the core!
Ford had replaced the rear axle seals under warranty, and apparently didn't get one center cap on completely.
Discount Tire replaced the valve stem for free, and I had to order another TPMS sensor.
Just a note on my experience this summer.
I only ordered the SS braided lines for the inside wheels. Wheel Masters Airless 2 hose inflation kit #WM 80022. After talking with TST Truck System i am NOT sure these are going to work with this system??
Won't know until I receive them from E Trailer
Hate to hear that..........I'm NOT real thrilled about any dealers!
hobo.labo
11-05-2005 09:56 AM
