Need advice on best floor jack for 7.3 with Off Road Package
Hey guys,
Im officially sick and tired of messing with my bottle jack every time I need to lift the truck up onto jack stands. I have some small cheapy floor jacks but they dont reach high enough to touch the axles so I use the bottle jack with pieces of wood underneath but its time consuming and then I have to lower it in stages with the jack stands and bottle jack.
Ramps arent tall enough.
I see two options but maybe you all know something I dont.
High Lift "Farm Jack" that hooks to rims. I have a gravel driveway not concrete so this is nicer than trying to roll something with tiny metal wheels.
High Lift jack
Harbor Freight's 4 ton jack which goes to 21 inches. Daytona 4 ton
Along with some jack extenders...assuming they work with the Daytona.
Or maybe this cross beam from Harbr Freight:Cross beam (its only good for 3 tons.Will that break under the front axle?)
Thoughts?
High Lift jack
Thoughts?
Like you, I use an assortment of things to get my truck into the air in the appropriate pose.
I have been at the purchase screen for the extenders, but stopped short because I found it hard to pay the prices I found for a piece of solid steel that does nothing other than exist between the jack and the truck.
In addition, I am not sure if your truck is a 4x4 or not, but I don't think a 21" lift from the Daytona will get a wheel off the ground if jacking under the frame. If under the axle, you will have to fight with the differential and spring perch on the drivers side to fit the jack and stand in there.
Subscribed to see what you come up with for a solution because Santa Claus is coming soon and I might put your solution on my list!
Daytona with wood boards underneath?
I have the Harbor freight / Pittsburgh 3 ton rapid pump...think its 18 3/4" height. I haven't tried to lift the entire front end with it, but its more than enough to get any of the 4 corners off the ground to get the stands under and pull a wheel...
but i'm a stock height stock tire 2wd so ymmv
fwiw I had a high lift from back in my Jeep days, one of the best all around tools I've ever owned, even with +7" lift over stock and 35's on sand it would get the wheel off the ground even on sand...could even help get you unstuck in a pinch as a make shift winch...not sure I'd want to use it as a regular/everyday method of lifting though
How do you get a jack stand under the front axle near the differential when the jack perch is taking all of the available space?
I have a floor jack that will not lift via the frame enough to get the tires off the ground unless I use something under the jack or on the jack perch. It is a large floor jack as well.
The Harbor Freight Dayton jack has held up well to daily use for about 8 years in my shop. I bought it as a temporary replacement when my snap-on jack was being rebuilt. I’d buy another.
fwiw, My my truck has 40” tires and a 10” lift, I jack it up by the axle and then put jack stands under the axle or the frame depending on what I am working on.
