Air Horn
Air Horn
I installed air bags recently and want to eventually add a horn. Not looking for the destroy your eardrums train horn, but more of a solid big rig sound that is well enough to get the point across. I've not had air horns before so could use some advice
My WirelessAir pump will suffice? What size tank should I get? Any advice on non-train horns? I know I'll need fittings, line, and likely a gauge
I've seen a couple posts of folks going with Kleinn train horn kits, but I'm only expecting a few hundred for these add-ons. Thanks!
Check out Horn Blasters they have a bunch of good stuff. They know their stuff, tank size and compressor size is really dependent on what horns you get. They will be glad to help you. They helped me!!!!!
So I'm like the OP - want a louder horn, but not a train horn.
Supposedly Harbor Freight sells something called Big Bertha or something like that that is electric and over 100db. Sorry I don't have more info on it. It was mentioned at work. But I certainly concur with the need here in DFW!
I have the Wolo 619 horn. It does not require air and definitely not a train horn but it supposed to be around 125 decibels. It is much louder and beefier than the stock horn and since I wasn't looking to get a ticket or cause an accident this fit my needs.
https://www.amazon.com/Wolo-619-Big-.../dp/B008J151H4
thanks!
Sec. § 547.501
Audible Warning Devices
(a)
A motor vehicle shall be equipped with a horn in good working condition that emits a sound audible under normal conditions at a distance of at least 200 feet.(b)
A vehicle may not be equipped with and a person may not use on a vehicle a siren, whistle, or bell unless the vehicle is:(1)
a commercial vehicle that is equipped with a theft alarm signal device arranged so that the device cannot be used as an ordinary warning signal; or(2)
an authorized emergency vehicle that is equipped with a siren, whistle, or bell that complies with Section 547.702.(c)
A motor vehicle operator shall use a horn to provide audible warning only when necessary to insure safe operation.(d)
A warning device, including a horn, may not emit an unreasonably loud or harsh sound or a whistle.Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995.
I didn't think Arizona had a law so looked it up. It does say "...not emit an unreasonably loud or harsh sound or a whistle" but I'm not too worried about it. I only plan to use it during those special moments
A. A motor vehicle when operated on a highway shall be equipped with a horn that is in good working order and that is capable of emitting sound audible under normal conditions from a distance of at least two hundred feet. Any horn or other warning device shall not emit an unreasonably loud or harsh sound or a whistle.
B. If reasonably necessary to ensure the safe operation of a motor vehicle, the driver shall give an audible warning with the driver's horn but shall not otherwise use the horn when on a highway.
C. A vehicle shall not be equipped with and a person shall not use on a vehicle a siren, whistle or bell, except as otherwise permitted in this section.
D. A vehicle may but is not required to be equipped with a theft alarm signal device that is arranged so that it cannot be used by the driver as an ordinary warning signal.
E. An authorized emergency vehicle may be equipped with a siren, whistle or bell that is capable of emitting sound audible under normal conditions from a distance of at least five hundred feet and that is of a type approved by the department. The siren shall not be used except when the vehicle is operated in response to an emergency call or in the immediate pursuit of an actual or suspected violator of the law or when necessary to serve a civil traffic complaint. During these events the driver of the vehicle shall sound the siren when reasonably necessary to warn pedestrians and other drivers of the approach of the emergency vehicle.
F. A siren shall be allowed on a fire engine that is solely used for hobby or display purposes and that has been issued a historic vehicle license plate pursuant to section 28-2484 if either of the following applies:
1. The siren is covered and is not activated while a person is transporting or driving the vehicle to or from a parade, authorized assemblage of historic vehicles or test.
2. The siren is activated only in a parade, for an authorized assemblage of historic vehicles or for testing purposes.
See you are in Texas.. Here are just some of the regulations for Texas. Additionally, if a air horn like a train horn is discovered during a Texas Vehicle Inspection it will fail. There are also Federal Specs FMVSS standard 121 it must meet as well. Many states have similar requirements.
cause I can tell you they've NEVER failed my motor coach....and it has TRIPLE bells on it.
In the -Texas DPS inspection Procedure / Rules - there is absolutely no mention or reference related to TRAIN HORN or failure if a TRAIN HORN is connected.
The language is much to subjective & vague for enforcement.
WAY too subjective terminology: "unreasonably loud" "harsh".....according to who? measured by what?
