Looking for Disc brakes off a 73 to 78 ...
Old 11-11-2018, 11:21 PM
Kai's Avatar
Kai
Kai is offline
I am looking over the fence from the 1961-1966 F-100 camp. I just bought a 65 and want to convert to disc brakes, but do not want any aftermarket retrofit kit. I'd rather get all parts that cannot be purchased new from someone who has something left over and then buy new rotors, calipers and other parts to complete the set up. Since I am from Germany I cannot just buy a donor truck and take parts off myself. I will get DJM dream beams just in case that this is info needed to help find me the right parts.
Thank you for your help !!!
Old 11-11-2018, 11:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1973/79 F100 2WD & 1975/79 F150 2WD came standard equipment with front disc brakes.
Manual disc brakes were standard equipment on F100's, power disc brakes were optional, but were standard equipment on the F150's.
Living in Europe makes it tough to find parts for these trucks, but you should get all the parts from one specific truck.
Mixing parts from various years is not the way to go, because there are some differences.
Old 11-12-2018, 01:15 PM
Kai's Avatar
Kai
Kai is offline
Thanx Bill. That sure makes sense. Now I hope that someone here can sell me what I need. And no worries, no need to ship to Germany. I have a couple of addresses in the US that I can receive parts at and then carry them over the pond.
Old 11-12-2018, 01:35 PM
gittinwidit's Avatar
gittinwidit
gittinwidit is offline
If you plan on replacing anything you can purchase new, then you would only need the knuckles with all the hardware, brake distribution piece and the power brake booster brackets. I believe everything else can be sourced brand new. If that's your plan, I can PM a price.
Old 11-12-2018, 02:47 PM
wyrm73's Avatar
wyrm73
wyrm73 is offline
I am looking at this swap for my wife's 65. The research I have done indicates the 73 & 74 are the best years to get the spindles/ knuckles from as the kingpin is the exact same size as the 65. The 75-79 the king pin is the same diameter so it should work, but it is just a bit longer. As I understand it, the spindle determines the kingpin length, so it should still work, but it does add just a bit more having to remember which year the spindles came off in case you ever need to re-do the kingpins. Pretty much what Bill said- keep it as simple as possible if you can.
BeerNBikes
26
04-16-2015 05:34 PM
RhondaBruce
11-29-2011 05:50 PM
ford rangers
05-15-2011 12:35 PM
1954_5liter
06-17-2007 03:55 PM
clint1274
10-24-2002 04:35 PM
Quick Reply: Looking for Disc brakes off a 73 to 78 ...
