2011 F250 6.2l stalls?
Hello, i have been trying to fix a stalling issue with my truck for a few weeks now. If i disconect the battery for a while, the truck fires up and idles about 8 minutes and then dies immediately with no stumbling. After this happens its hard to start and takes many attempts. If i throttle it slightly i can keep it running and driving completely fine until i let off. No CEL or codes.
******THINGS I HAVE DONE ****
*PCM REPROGRAMMED
*ALL GROUNDS CLEANED
*ALL FUSES CHECKED
*FUEL PUMP RELAY REPLACED
*THROTTLE BODY CLEANED
*CANISTER PURGE VALVE SOLENOID
*REPLACED WIX OIL FILTER WITH MOTORCRAFT
ANY HELP OR IDEAS ARE GREATLY APPRECIATED
*PCM REPROGRAMMED
*ALL FUSES CHECKED
*PCM REPROGRAMMED
*ALL FUSES CHECKED
*PCM REPROGRAMMED
*ALL FUSES CHECKED
Now, I don’t know what that is supposed to be.....naybe someone that knows can chime in here; or you can look up thespecs yourself and verify what you have.
Good luck.
Just a guess here. What kind of pressure is your fuel pump putting out? Might need to check that, and see if it is in spec.
Good luck.
I have completely rebuilt the throttle body, even after my scanner shows it responding fine. The maf sensor is clean has voltage and is responsive to air flow even on the limited cranking.
However i did find many of my relays and power distribution box very coroded. Cleaned what i could as i cant find a replacement even online.
Thanks , yeah mine is at 152k and had the living **** kicked out of it plowing and being used for a railway. The 6.2l with the torque shift 6 is mechanically very tough. When mine ran it was smooth and shifted like day one. And im telling you it was driven VERY HARD. But always had electrical related issues since day one. Almost killed me and other co workers on many occasions when it would die driving along cliff sides.
2007sporttrac
09-16-2015 11:38 PM
lee_johnson_85
04-02-2012 07:04 PM
