One trip hauling with out EGT gage?
Old 10-30-2018, 12:58 PM
Metal twister's Avatar
Metal twister
Metal twister is offline
Think I know the answer but....... So i went and bought a building in Licking Mo. where I will be moving the shop to by the first of the year. The down side is ive had to completely drain the bank account to make it happen. With moving expenses and all the last minute BS I really am strapped. It looks like I will be making several trips between San Diego and Mo. pulling a 20’ trailer. If I old man it and go slow and easy is an egt gauge really necessary the first trip? I need real life advice here, not the 20/20 in a perfect world, money is no issue answer. Thanks guys its appreciated,
Old 10-30-2018, 01:19 PM
beef tits's Avatar
beef tits
beef tits is offline
The truck didn't come with a gauge from the factory... plenty of people haul without one.
Keep in on a tow tune and run the RPMs high when in doubt.
I drop to 4th gear on grades with any load. ("5th" gear for the dreamers who actually consider the ZF-6 to be a proper 6 spd)
Old 10-30-2018, 01:29 PM
roostercrows's Avatar
roostercrows
roostercrows is offline
My opinion,
Assuming your truck is running the way it should and given the mods I see in you signature, I wouldn't hesitate to do it.
I think you know your truck well enough to drive it conservatively and not get near the upper limits of the EGT range.
If your really concerned, disconnect your tuner.
Old 10-30-2018, 06:49 PM
dn29626's Avatar
dn29626
dn29626 is offline
You are a manual tranny, so...keep an eye on the water temps and you should be good.
Old 10-30-2018, 08:21 PM
Metal twister
Thanks guys, about what I was expecting to hear. It is on the short list of projects but my usual procrastination... oh well! More than the cash im out of time to even work in the install. Moving a shop cross country is a major PITA! Thanks for the replys it helps settle the mind with one less thing to think about. Appreciated!
Old 10-30-2018, 11:00 PM
'88 E-350's Avatar
'88 E-350
'88 E-350 is offline
That's probably what most people thought before they melted pistons at "normal" temperatures.
Old 10-30-2018, 11:04 PM
'88 E-350's Avatar
'88 E-350
I would put it to stock (no tune) as that'll be safe to run as hard as needed to make the trip. I've read of several 'safe towing' tunes creating excessive EGTs.
Old 10-31-2018, 01:56 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
What '88-F350 said. "Guessing" that your EGT's are OK with a tuner is literally playing with fire!
Old 10-31-2018, 03:45 PM
dn29626's Avatar
dn29626
dn29626 is offline
Originally Posted by '88 E-350
...melted pistons at "normal" temperatures...
How many 7.3's do you personally know of that melted pistons?
To OP, if you get concerned, stop and let he truck sit for a cool down.
Old 10-31-2018, 03:55 PM
Metal twister
Real world opposed to he Internet world... which is closer to reality? How many here has had towing over heating issues? And why? Tunner or cooling system issues?
Old 10-31-2018, 05:31 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Both my trucks, zf6 n auto, all stock.etc, and im in the egt gauge more than eyeballs on the road, towing 8kT.H. no boost leaks..etc. Can hit 1200 just getn on freeway.
Old 10-31-2018, 09:14 PM
Wes444's Avatar
Wes444
Wes444 is offline
Received 1,133 Likes on 645 Posts
Well I'll give my real world experience, vs perfect world dreamers. No boost leaks, Towing our 5th wheel using Gear Head's 2 "Tow" tunes on a TS6 the EGTs hover at 1k on a very slight incline, any obvious hill and I'm watching the EGTs like a hawk and lifting my right foot to keep them at 1240, or I'm down shifting, or even dropping into "stock" tune to keep temps in check. Even in stock form if you keep it floored in 6th on a good hill you'll see 1200.
Also, EGT and the water temp gauge? No, not even. After 5 minutes of towing the factory coolant temp gauge stays the same, my aftermarket EGT and oil temp gauges move rapidly based on engine rpm/load vs coolant pretty much stays in the middle without moving
Keep the RPMs up when it isn't completely flat and tunes off and you should be ok with no gauge
Old 10-31-2018, 10:44 PM
'88 E-350's Avatar
'88 E-350
To OP, if you are get concerned, stop and let he truck sit for a cool down.
Personally meaning I was in the truck? 0
Read about and saw photos of the carnage? Lots.
Combustion chamber temps can rise very quickly. Eventually that heat transfers through the cylinders and heads to reach the coolant, and eventually that coolant will start to heat up the sensor. By the time the coolant temp gauge rises to alarming temperatures the pistons, or other parts, might be wrecked. I've read of this happening with both gas and diesel engines repeatedly.
Stop and let the truck cool is NOT the thing to do. Drop speed and downshift to reduce load and increase coolant and air flow. If that fails to reverse the rising temperature you stop as a last ditch effort.
Old 11-01-2018, 07:27 PM
dn29626's Avatar
dn29626
dn29626 is offline
OP-How many miles is this, one way? How much weight will be loaded onto the trailer, GN or tag-a-long?
Old 11-01-2018, 09:38 PM
Metal twister
not sure of the weight. Heavy mfg. equipment lathes, mill, 8’ shear, couple benders and dies. On a 20’ bumper tow trailer and in the truck. I was going to order one last night but wouldnt get it in time? San Diego to Mo. about 1500 miles. Coming back empty shouldnt be an issue.
Quick Reply: One trip hauling with out EGT gage?
