Won't start, hear clicking under dash while cranking
My 2001 7.3, on occasion will just crank and not start. At the time it is cranking and not starting I hear a fast clicking under the dash on the drivers side. I'll stop cranking it and try cranking again and it starts. One time I had to stop and start cranking it about 5 times before it would start. So far, knock on wood, I've been able to start it and haven't been stranded. I am hoping someone can help me figure out what this issue is so I can get it resolved before I get stuck somewhere. Any advise as to what to check? Thank you
It could also be a dealer installed aftermarket security system. I have one in mine which is tied to a motion detector. If I wait too long to stat the engine after getting in, while I'm getting "situated", the relay starts clicking and the truck will not start. The solution for me is to unlock the doors with the key fob and then it will start. I go one step further, though after unlocking, and re-lock the doors, wait 3-5 seconds, and then unlock... all of which resets the security system completely.
Are you running Torque Pro or any kind of bluetooth OBD2 adapter?
Every now and then I will get clicking under the dash and the truck won't start. I reach down and pull the OBD2 BT adapter off and everything's fine.
It seems to happen more often when I have Torque open on my phone. If I have the BT adapter in but Torque closed (not connected to the adapter/truck) it happens much less frequently.
Just now getting around to updating this thread, thought I'd update in case anyone else has the same symptoms. It was a bad battery connection. The battery had juice but when I put my meter on the connectors it dropped 2 volts. Cleaned the connectors on the passenger side battery and it cranks like crazy. Thanks for the help...
IHMANKY
03-13-2011 08:43 PM
