390 rebuild/cam selection
Hey there,
the time has come to rebuild the 390 in my 76 f100. It's the original engine with a lot of miles on it, it also sat for roughly 8 years so it has blow by, and leaks a copious amount of oil from pretty much everywhere. (despite this I've been daily driving it with no problems) It has a 650cfm edelbrock on top of a performer rpm intake, HEI style distributor, hooker headers and true dual exhaust. (going to be reusing all of these) Truck a 2wd short box, also has 4.10s and a posi. Its going to be my daily driver, so I don't want it to be too radical, and I want it to run on 87 octane. I plan on using better pistons to bump the compression a bit, and a better cam. Would like to keep the heads stock, as I'm on a budget. My engine builder suggested a lunati voodoo 268 cam. Anyone have any experience with one? Do you guys have any other cams you'd recommend? What kind of horsepower/torque numbers am i looking at? Id be happy if I was close to 300hp and 400ft lbs. Anything else in general you guys would advise/recommend is also greatly appreciated.
Thanks,
Jared
Thanks,
Jared
First off, confirm that is is a 390 and not a 360 by measuring the stroke. You wouldn't want to buy the wrong parts. There is no reliable external difference between a 390 and a 360.
Alternatively, you can leave that up to your machine shop. The crankshaft, rods and pistons are different and your machinest should be able to tell you what you actually have.
All of the above assumes that you are not the original owner with knowledge of the truck's provenance, VIN code, etc.
Is that Lunati a split pattern cam? If you are interested in a Comp Cam 268H I have one that’s been sitting in my garage for the last few years. 33-224-3 These are fairly tried and true for the FE.
I bought the complete kit but only used the timing set and lifters out of it. So cam, springs, retainers, locks, valve stem seals are included. You can have everything for $120, shipping not included. PM me if you are interested.
I have a 390 I'm rebuilding I have a Lunati 10330700K - Lunati Voodoo Cam and Lifter Kits from summit
My machinist and I agree that it would work will in my truck (building to tow/haul)
It will also help with the mid-range bog down that these trucks have
tpdaniels
03-24-2013 11:16 AM
choppers ford
09-08-2010 09:09 AM
ramarado
04-20-2008 11:46 AM
TKKTommyboy
03-07-2006 02:28 PM
linrick1
11-04-2004 06:41 PM
