Instrument Cluster.. Voltage Guage ?
I have a 93 F350 with a 460 cu in engine gas. Last year the oil pressure guage stopped working. I changed the sending unit several times with no change. So I know there is nothing I can do about that. I had installed these new LED bulbs in the cluster so I am wondering if that could be part of the issue ??? When I put the LED bulbs in all the sockets I noticed that there is a Red battery light on the bottom of the cluster that just stays on all the time. Don't know what this is telling me. . Yesterday I noticed the voltage guage would just go up to 8 and stay there. I put a new battery in in June and check the voltage today and it is fully charged. Today I started the engine and then disconnected the battery to see if the alternator was putting out enough to run the engine. It kept running. so I figure the alternator is good. Any advise ???? Thanks.. Fred z
Ground out the oil pressure sending unit wire to test the wiring and gauge. It should peg at the high end of the scale. If it does not then there is an issue with the wiring or (most likely) the gauge.
The red battery light indicates that you are not charging the battery. You do not check charging system voltage by disconnecting the battery while it is running. Instead, you put the meter leads on the battery with everything connected to see what voltage you have. You should have around 14 volts.
Never disconnect the battery while it is running!!!
This can send a voltage spike to over 100 volts.
These newer trucks (OBS) have electronic devices can be messed up.
Your lucky if did not mess up the PCM, radio and other sensors.
Only time will tell as now you may have other problems down the road from doing this.
................I had installed these new LED bulbs in the cluster so I am wondering if that could be part of the issue ??? When I put the LED bulbs in all the sockets I noticed that there is a Red battery light on the bottom of the cluster that just stays on all the time. Don't know what this is telling me. . Yesterday I noticed the voltage guage would just go up to 8 and stay there. I put a new battery in in June and check the voltage today and it is fully charged. Today I started the engine and then disconnected the battery to see if the alternator was putting out enough to run the engine. It kept running. so I figure the alternator is good. Any advise ???? Thanks.. Fred z
Get a real meter and check at the battery with engine running. These gauges are mostly fancy idiot lights and are not accurate .
Not to criticize but because I was curious. I looked up your other post which was over 5 years ago and involved overheating (solved by adding water) and both the ABS and red brake lights illuminated. To me, overheating solved by adding water indicates the system was low and you don’t check fluid levels. Both brake warning lights on is usually due to the brake fluid level being low in the master cylinder either because of a leak or the friction material wears over time and the fluid level will drop. I am guessing that a caliper was dragging causing your issue but since you never came back and said what it was I can only guess.
It appears that you do not do routine maintenance or take it somewhere to have these items checked if you cannot do it yourself. Saying that you replaced the sending unit several times (that should be a clue that it wasn’t the problem) so there is nothing you can do doesn’t make any sense to me. Check the wiring or the gauge and then if the gauge is bad, go to a junkyard and get one or find one online and replace it.
The ABS light turned out to be the ABS modulator valve. My F350 is a heavy truck and when I breaks down my AAA membership won't tow it so I have to pay a private tow company,$$$,, so I do check under the hood quite a bit. The first two oil sending units didn't look exactly like the one to took out and I thought the first one could have just malfunctioned. and the third one from a different parts store did look like the original one yet still the gauge didn't move. Just a logical process of elimination. So now I know how to check the oil gauge and wiring. thanks.
As for the alternator check method... Decades ago a heard this was how to see if the engine was running off the battery alone. I did make sure I turned the engine off before reconnecting the terminals. Thus avoiding a voltage spike. Thanks again for following up on this post. Fredz
