Spare Tire Carrier Part Help
Hi FTE,
I've been away from my 1965 F100 Flareside project for a while due to work but I ready to reengage again!
I need help with a two things -
I'd happily exchange a few "dead presidents" If you have a pattern or would be willing to make me a pattern for the short wheel base (114"-115") truck.
Thanks in advance! John
- first- I'm looking for the spare tire wheel carrier floor to sill reinforcement plate - part # C1TB-1413-A,
- second - I'm looking for a "bolt up" pattern for the mounting of the spare tire carrier rack. I'm not comfortable just "eyeing" the correct placement and drilling the holes only to find I've drilled the wrong locations.
Since you are drilling out new,here is the bolt pattern for the top 4 holes.
Once you do these, then the bottom holes will fall into place, assuming the carrier is not bent
these measurements are from the back of the stake pocket towards back of bed and the top crease of the bedside panel (right where it starts to angle)
Mark 2 parallel lines from top crease 1" and 1 3/4"
top line the holes are at 6" and 18"
bottom line the holes are 3 1/2 and 15 1/2
1. 1 3/4" down x 3 1/2 out
2. 1 " down x 6" out
3. 1 3/4 down x 15 1/2 out
4. 1 " down x 18" out
BTW, I am looking for the bottom angle piece as well, so I will have to make it out of angle stock if I dont find one
Thanks Bert!
I have the top reinforcement plate part #1407, should I align the first bolt hole with the 6" top line mark? If so, the remaining top bolt holes are then set by those in the reinforcement plate.
I assume I'm too will have to fabricate the bottom reinforcement plate once I establish the correct bottom hole locations.
tcspicker
02-05-2015 06:32 PM
firstrider
08-15-2013 07:11 AM
Becky_is_a_66
01-12-2013 09:37 PM
F100PJ
12-16-2011 09:47 PM
