slight vibration after V/c spring swap
I swapped my springs for v front and c rear, I gained about 2 inches or so front and rear, I noticed on the fwy over 70 I get a vibration, I did not get it aligned as I wanted the springs to settle first it is slightly off as my steering is not quite on center, is there any way it could be pinion angle? reason being I feel it in my but more than the steering wheel.
The vibration is caused from the u joints being out of phase which is a result of you changing the output shaft angle while the pinion angle likely stayed the same.
when you lifted the vehicle the output shaft angle when UP a few degrees and the pinion angle was not moved to keep them parallel.
thisos a great illustration of what generates the vibration
You will need to measure the output shaft, pinion and driveshaft angles at static ride height to figure out what shims to use.
this calculator can be of help.
https://spicerparts.com/calculators/...gle-calculator
52 panel
25
04-19-2007 10:16 AM
1969FordF250
08-28-2004 09:13 PM
