After my wife hauled a load of hay, the shift selector was screwed up, when the selector is showing reverse the trany is in park, showing neutral the trany is in reverse, drive is neutral, second is drive. It drives ok shifts into OD when its suppose to. Any ideas? Thanks, Walt
My Wife was driving, I need to get under to see if its the adjustment or loose bolts on the steering shaft. To busy fixing other stuff for my wife.
Thanks guys. Walt
