1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What Is It? See photo
Old 10-19-2018, 12:06 PM
PE1948's Avatar
PE1948
PE1948 is offline
1999 (early build) F250 Super Duty Extended Cab 4X4 diesel / automatic. Recently bought the truck used. Lots of additional wiring had been added over the years of uncertain purpose. The current owner, a recent widow, is unable to address my wiring questions. So...Inside the frame beneath the the drivers side and just aft of the high pressure fuel pump is an odd device that I need help identifying. See photos. It appears to be an add on solenoid valve. About 2" long, 1" diameter with a single control wire routed up into the dash board. Two 1/4" rubber hoses are attached with screw type SS band clamps. Hence my suspicion that it is after market as Ford does not routinely use these. One hose terminates, simply open, about 12" back. The opposite hose is routed forward into the nether-lands of the engine compartment. In the process of tracing the add on wiring I found the wire to this thing frayed, bare copper touching the frame. I cut away the wire leaving the valve inoperable. I expected problems as a result. Nothing. The truck seems to operate just fine (now 2500 miles) without an issue.
Any clues?
Old 10-19-2018, 10:40 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Power it up and see what sparks.
Old 10-20-2018, 10:41 PM
Mike321's Avatar
Mike321
Mike321 is offline
Clean it and see if you can find a part number.
F-1
02-23-2017 05:51 PM
hot-rod
13
10-28-2016 08:02 PM
ssmitch
04-19-2015 04:40 PM
agmech2
29
02-22-2013 04:16 PM
caere
06-11-2010 01:23 AM
Quick Reply: What Is It? See photo
