tire size
tire size
Does someone know if I change the stock 18" rim with 275/65-18 tires to a 20x9" rim with 295/65-20 tires, if that will still raise overall height?
All things considered I should loose 2" in sidewall and the overall axle height should remain the same?? reason I ask is I've read on some tire/ rim options, the tire will sit higher than some others.
My overall intent is not to raise the truck any Higher, I traded in a 2015 Dirty Max 3500HD for this 2019 F350 and the Ford is definitely higher, and I pull a 5th wheel.
Ok, thanks, I can live with 1.5" I'll have to take it in to have the speedo adjusted.
I ordered this truck, the 20" rim was an upgrade and I didn't want to finance them, so I figured ill have a lot more choice of rim style and just upgrade to the 20" rim after getting the truck, and I can sell the takeoffs and recoup some money. I compared a new Dirty Max to the new super duty, and Ford just has them beat, with a lot of bells and whistles, if im going to keep a truck for the next 10 years, I figure the aluminum body makes a lot of sense as to trade in value, along with the step in the tailgate(im getting older) why doesn't every truck have this, and the camera system is awesome.
Rob
Rob
cdherman
04-27-2005 01:20 AM
