My First Project: 1988 Ford F-150
Hello FTE!
I'm new to new the board, and new to taking on a project. I wanted a clean classic pickup truck to do random hauling and I'm now the new caretaker of an 88 F-150 that was well taken care of, BUT, it's been sitting outside for nearly ten years!. It's a V8 automatic with 85k original miles.
Now, I'm trying to come up with a checklist of everything I need to have done/checked before I even attempt to crank it.
What I can tell so far:
1) Tires are dry rotted, need replacement
2) Gas is bad, needs to removed
3) ALL fluids need to be changed
- transmission flush
- engine oil
- oil filter
- engine air filter
- brake fluid
- engine coolant
- ac/cooling system fluids
4) Spark plugs
5) Drive belts
6) Brake system lines
6) Radiator hoses
7) New battery
Few questions:
1. Am I missing anything?
2. What should/can I do to get this thing running?
3. I'm a novice, what should I consider doing myself vs taking to a shop?
4. Is there any particular order I should do things in?
5. Anything I should be mindful of?
Thanks in advance and I look forward to sharing my progress with you all!
- engine oil
- oil filter
- engine air filter
- brake fluid
- engine coolant
4) Spark plugs
5) Drive belts
6) Radiator hoses
7) New battery
Few questions:
If your tanks are rusty internally just replace them. They are fairly cheap and you could spend just as much or more cleaning them as just purchasing new ones. Ask me how I know.
There is nothing on that list that a novice can't do especially with help from here. Get a repair manual and a decent set of tools.
Also a truck that has been sitting will have a lot of little things that crop up.
leeknivek
12-10-2014 07:21 PM
BritGuy
16
08-10-2011 11:40 PM
AndrewDahlin
09-12-2010 09:18 PM
felixr
01-14-2005 09:48 AM
