Doors won't close
The original weatherstrips were not available at the parts counter, they were only installed on new trucks.
The Ford 'service part replacement' weatherstrips were much fatter and this is what the repro weatherstrips are based on.
This is a typical problem with the door weatherstrips because the original factory installed weatherstrips were almost flat, so the doors would close properly on dealer lots.
I would suggest using a couple ratchet straps, attaching one door to the other. Pull the striker receivers off the cab door jam and strap/pull the doors in until they are flush. Leave them there for at least a few days if possible. Once the doors close properly, then adjust your strikers.
Installed new weatherstrip on my doors almost a year ago. Since they were much thicker than the originals, I adjusted the striker accordingly, letting the door close with some extra effort, but not too much to be annoying. Gradually, maybe every week or so, I adjusted the striker inward until the doors aligned perfectly flush with the cab. It really didn't take very long (maybe a month or so) and the doors close effortlessly now.
I have noticed on occasion though, since the cab is so airtight now, sometimes the air pressure pushes back when closing the door. If I leave a vent open or crack a window it lets the pressure escape and isn't a problem. It's not a problem with the weatherstrip, it's just that the extra volume of air has no place to go.
