What shocks to get
Old 10-15-2018, 02:30 PM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
What shocks to get
Its time to replace the shocks on the Ex (2005 6.0). It has Modded V & modded B springs. When we installed the ne springs th front was a little low so we added a leaf from the old rear springs to the front. I would like to put Bilstiens but not sure what to get. Can any of you help me with what the correct shocks to order. Thanks Billy
Old 10-15-2018, 05:37 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
I used F250 shocks from the same year on my 2000 with leveled V, modded C’s. Not exactly your set up.
How do your measurements match up with those here?
Old 10-16-2018, 10:08 AM
ithaca1230's Avatar
ithaca1230
The measurements are 24 1/2 front Center of hub to fender and 26 1/2 rear center of hub to fender. I do plow with it in the winter and have a aftermarket bumper and winch in the front.
Thanks
Old 10-16-2018, 03:05 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Thanks
We’re pretty close, I’m at 25.5'' front; 27'' rear.
Old 10-16-2018, 03:47 PM
ithaca1230's Avatar
ithaca1230
Im trying to figure out what length shocks to get
Old 10-16-2018, 06:01 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
When I got my new springs I also got Bilstein shocks meant for the F250, but I think my front ones are toast after only a year. I think I over extended them while on some twisty off roading this summer. They aren’t compressing anymore, they feel like 20 year old shocks. I’m going to order some Ranchos RS9000xl for an Ex with a 4” lift. Getting the ones with the extra lift will also help when I have the rear bags aired up.
Old 10-16-2018, 07:23 PM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
Bilstein has a limited lifetime warranty, if it is the fault of the shock (materials/workmanship) they will replace it. If you overextended them, they are likely to tell you they were incorrectly sized for the application and the failure is NOT the fault of the shock.
Changing to another manufacturer without correctly sizing for your application will result in the same failure under the same circumstances. What springs do you have? Did you not like the ride quality of the Bilsteins? I am in the market, and have not been happy with Ranchos in the past.
Old 10-16-2018, 08:44 PM
dualwheels66
The springs are from ATS, V code kit and C code kit. I have the Bilstein 4600 series, seemed a little stiff. Theses shocks have been great for me in the past. I will call ATS in the morning and see what Mike suggests.
Old 10-16-2018, 08:56 PM
PrescottIce
Okay, good to know. I'm planning on a different route, ProComp springs possibly with Bilstein 5125s. The latter are a little stiffer than the 4600s in compression, less so in rebound.
Old 10-16-2018, 09:17 PM
dualwheels66
I meant Junior not Mike.
Old 10-17-2018, 08:35 AM
ithaca1230's Avatar
ithaca1230
I have ranchos now and they are shot. Im tryingto get the correct ones to avoid damaging them
Old 10-17-2018, 03:18 PM
dualwheels66
I went over to ATS today and talked to Junior, he recommends staying with stock length shocks for my set up. I might just due a pair of cheapo shocks and see if that makes a difference.
hink10
09-28-2012 12:44 PM
rodneywar
08-26-2012 10:10 PM
ToyhaulinEX
02-23-2012 04:38 PM
DOUG5G
Aerostar
03-17-2007 08:39 PM
yozsi
10-01-2004 12:16 PM
Quick Reply: What shocks to get
