Quick question, on my 2014 I had an option the showed oil life, on my 2017 lariat I’m not able to see it and only see oil life in the monthly email. Anyone know if it is there or if I can enable it in forscan?
The gas trucks use basically a day / mileage countdown timer to determine oil life. Diesel trucks use the "intelligent" oil minder which is based on many things including idling vs highway time, speed, engine oil temps, miles / days, number of regenerations, etc. Since this oil life percent remaining might "change" if you are suddenly doing a lot of highway driving or suddenly idling a lot...Ford simply doesn't display it. You'll still get the warning when its time to change...
And you can use Forscan to display the oil life PID as well. The truck will also give you two warnings, “change oil soon”, and “change oil now”. Soon is 1000 miles notice, change oil now is about 150 mile IIRC.
Thanks all, I will jump on forscan and see if I can find it, I understand that it will vary based on driving but liked having the knowledge when planning trips etc...
My 2019 PSD platinum shows oil life under the Advanced options on the information display. You have to be stopped to enter that menu but it does show the % of oil life left. It also has the oil life percentage on the app on my phone.
