2008 Metal Rattle Noise at Idle
Been getting a metal rattling noise under my 08. First I thought I was an exhaust leak but it was too intermittent. Some days it wasn’t even there.
I did an oil oil change today and noticed the metal cover between the trans and engine is rattleing causing the noise. I made some space in there gently with a screwdriver so it won’t contact the trans anymore but it’s still rattles. Any advice
Im thinking of putting some jb [small amount] weld in there just so that cover doesn’t bounce around. But I don’t wanna make a mess.
Pics below
I, too, originally though my rattle came from that exact spot a few months ago, after just buying my truck. My noise wasn’t at idle, though, but at higher rpms. Ended up being a broken exhaust stud.
Sknce your is at idle, I would check the catalytic converter covers first. They are usually the first ‘noise makers’ due to the heat cycles they see. I have used inconel safety wire to quiet them down, putting a few tight wraps on the ends.
— Dave
— Dave
Sparkplugless
15
07-15-2015 10:08 AM
