AC Issue
AC Issue
Morning everyone,
About two days ago my AC just gave up the ghost and quit working. Turns out the Compressor isn't even kicking on. I've already done some searching and tested out jumping the pressure switches (not at the same time) and still nothing. Compressor turns easily by hand with minimal drag that is expected. Fuse 9 good, as the blower wouldn't work either if it were toast.
I've tested for power at each connector and I get nothing. Is there a relay or something that I'm missing that controls voltage to the compressor and drier? I went from nice, cold AC to none in a single day.
The system has a leak somewhere, but it's not a fast enough leak to purge all the freon (yes, I know it's R134a) in a matter of months. I would also still be able to jump the switch and test for clutch engagement even if the system is low.
On the subject of clutch engagement, turning the **** to AC or AC Max is not locking the clutch in place, which is why I don't believe it's getting power whatsoever. What else should I look at?
I plan on refreshing the AC and replacing the evap core, but that was going to be a task for this winter.
Yup, found it. Price isn't too bad.
I guess now I need to weigh the pros and cons of just replacing the clutch or refreshing the entire AC system this winter with brand new everything.
I'm just glad it was something I simply overlooked, like the wrong fuse, haha. These last two days on the road with no AC have been grueling.
This, my Durango, and the Jeep are the only vehicles with working AC. The Jeep doesn't do me any good for work, and my dad drives my Durango daily, so this is all I have. My Mercedes are all for regular commuting stuff in the winter til I get the AC sorted on both of them.
pecanflyboy
11-05-2012 12:33 PM
big poppa
20
01-09-2011 07:52 PM
