2018 F350 - Door rattle (sounds like a typewriter)
Hi,
This past summer I ordered and received a 2018 F350. It now has 2500 miles on it. About 1000 miles ago, a rattle developed in the driver door that honestly sounds like a typewriter. I have uploaded a video to my youtube channel - turn up the volume as loud as you can tolerate.
Here are some annoying observations:
Any thoughts?
Eric
- It will do it after the truck sits for an extended period of time.
- It stops after about 15 minutes of driving
- Opening and closing the door doesn't stop it
- Pulling on the door release (not enough to open the door) doesn't stop it
- Opening the door while driving doesn't stop it
- It happens at any speed
- The slightest bump in the road will cause it
- At stop, closing the door doesn't make the noise show up
- For certain it is coming from the driver's door
Any thoughts?
Eric
It sounds almost like loose op-rods clicking against something, but it could be several other items in there. If it stops after awhile, perhaps it has worked its way into a semi-secure location, and slamming the door closed would dislodge it again. If you want to attempt going inside the door yourself, I've attached a video I used to install Jimmi-Jammers in mine.
Hi,
This past summer I ordered and received a 2018 F350. It now has 2500 miles on it. About 1000 miles ago, a rattle developed in the driver door that honestly sounds like a typewriter. I have uploaded a video to my youtube channel - turn up the volume as loud as you can tolerate. https://youtu.be/D3tcnF3ars4
Any thoughts?
Eric
Any thoughts?
Eric
holy hell for as consistent as that is it should be a breeze to find. remove door panel, drive with someone in back seat and look for sound from inside the door. Its the random little noises that are hard. Hate to say it I removed the b pillar panels and the seatbelt mechanism makes a ton of noise ranging from clicks, spring etc. I don't think that I your source though. Keep us updated.
2017 F250 6.2 with a similar rattle, maybe not as pronounced as yours, when driving over bumpy areas when cool/cold outside. Would mostly stop after a few minutes when truck interior warmed up. My noise sounded like it was coming from inside the door but actually originated from the fixed louvered window vent (not the forward facing vent) located on the side of the dash directly across from the mirror mount cover. Putting my fingers firmly on the vent while driving was enough to stop the noise. I ended up prying off the louvered vent cover and lightly shaving some excess plastic vent piping that seemed to be rubbing on the cover. No more noise....so far.
I will keep everyone updated.
Another update on my door noise saga. I have isolated the noise to the lower door hinge. If you put your hand on the door, just below the hinge, you can feel a "pop". This sound from the hinge is the same noise I hear going down the road (the first video I posted).
Prior to figuring out the correlation with the door hinge, I have I have removed the door panel multiple times and have driven the truck and the noise shows up, therefore, I can rule out the door panel. I have taped, padded everything I can touch within the door and nothing helps.
If I can get the noise to show up at the dealership, they will attempt to fix it. Very frustrating.
Any thoughts?
Any thoughts?
FWIW - Similar annoying rattle / noise / clicking - many of my observations were similar to yours. Thought they were coming from right rear door, bed/frame area - finally went under the truck and tightened all of the running board bolts and the noise(s) went away. Some of the bolts were very loose!
