After Market Heater System Recommendation?
So previous owner literally ripped every heater component out, truck was originally AC truck. So I need to install a heating system and was looking for recommendations. I know I could buy one from part truck or salvage yard but was thinking an aftermarket heater may be better than an original I know the aftermarket AC unit are a great deal better than the original
I have never known a stock heater, car or truck, not cook you out if the core not plugged.
Well maybe a VW bug heater but then how hot can an air cooled motor get in winter?
Now I don't know about you year trucks but the 80-86 trucks have different firewalls between AC & Non-AC trucks so something to look into if going with stock parts.
Dave - - - -
Dave - - - -
Did the truck originally have factory installed integral A/C (combined with the heater) or deluxe dealer installed A/C (combined with the heater)?
Factory A/C: A/C controls are in the same panel as the heater controls, has the huge evaporator case at the right rear corner of the engine compartment.
Deluxe Dealer installed A/C has two A/C switches located in the HUGE dash bezel that sweeps across the entire right side of the dash.
If factory A/C, you'd be better off finding a 1973/79 F100/350 or 1978/79 Bronco with just the heater only or Economy dealer installed A/C (not combined w/the heater)...and use all the parts.
Check out Flex A Lite Mojave heater. https://www.flex-a-lite.com/mojave-heater-179.html
https://shop.broncograveyard.com/Moj...SABEgL9-fD_BwE
If you are going this route, be prepared for some fabrication. Do you still plan to use vacuum control? How will you connect the ducting, run the heater hose, etc. Think it through. Here's mine. It still works great and I stay cozy in the winter.
https://www.ford-trucks.com/forums/1...ng-my-way.html
84espy thanks for the reminder. 16 in. Stoker w/3 x 3 in. Outlets ? Maradyne Mobile Products
I would look for a truck without AC if you just want a heater, remove it all along with big enough piece of firewall. Not saying that there might not be one somewhere, but the aftermarket units even with ac don't have fresh air intake. If your in humid cool/cold climate your going to have fogged up windows. It was a big advance when Ford brought out the Magic Air heater.
77f2504by4
27
06-24-2014 01:39 PM
blumax
06-07-2011 08:50 PM
