Factory Ford bling 8.8 differential cover... poor-boy style on the cheap.
Aluminum differential cover with ribs/cooling fins, a bottom drain plug and a magnetic fill plug for next to nothing. What more could ya ask for.
Rolled around under an IRS Explorer for a bit, and yanked it's diff cover. Did some cutting, grinding and sanding to pretty it up.
Going to swap out the rear tin cover on my OBS standard cab, shortbox 4x4 with it.
An FYI to any of us other enterprising cheap skates & hard-heads.
Climbed under Mountaineer today. Be prepared to drop the whole center-section since the whole point of this piece is as a structural member.
You can't just pull the bolts out & peel the cover off since there are 2 inside the buttresses & the cross-member covers them.
It was heat index of 105* so I passed on pulling it today.
Guy stopped & told me that these IRS's are hot ticket to build trikes out of.
Yeah, use the fill hole in your truck housing for the proper fluid height level. The small plug in the cover is magnetic though, so at least it grabs any metal bits that might otherwise float around in the fluid.
2004 and up Explorers & Mountaineers have the independent Rear suspension.
With the Explorers, everything is bolts, threaded into tapped holes, so no nuts to hold.
Pull the four driveshaft bolts (12mm 12-point) and drop the shaft. Then pull the bottom three, and top four (12mm) diff cover bolts. Next pull the (18mm) rear bolts that mount the cover mousing to the frame, then remove the front pinion mount bolt (there's only three bolts that mount the entire differential into the chassis) Now rotate the differential down (it'll rotate on the axle shafts) and pull the remaining three cover bolts, and it's out.
To see how long it took, I timed it. From the moment I set my tool box down in the dirt, to the moment I stood up with the cover in my hand, It took a total of 26 minutes. The rear mounted spair tire was already removed, so that helped with the time a little, as it freed up some space to work. If I were to do it again, and used a cordless impact wrench, instead of hand wrenches and ratchets, I could probably get it down to about 15 minutes.
Last edited by Dirtbag; 09-30-2018 at 07:04 PM. Reason: tA fex me spall'n miss-taKs
