Speedo no bueno
Old 09-19-2018, 07:08 PM
Matus16's Avatar
Matus16
Matus16 is offline
Speedo no bueno
I have a 1985 F150, 4.9l i6 and cannot get the speedometer working for the life of me. I've bought a brand new cable that matched the old one exactly from Jeff's bronco graveyard. I swapped that out still didn't fix it. I noticed that the 17tooth gear looked a little worn on some of the gears so I bought a new one and just replaced it today, still not working. I do not have a speed sensor. It's a pretty simple setup, instrument cluster to tranny with nothing in between. Any suggestions?
Old 09-19-2018, 07:55 PM
Matus16's Avatar
Matus16
Matus16 is offline
Tried the drill method and she fires right up so maybe something is not meshing in the tranny?
Old 09-20-2018, 07:58 AM
Rembrant's Avatar
Rembrant
Rembrant is offline
Yup. Something wrong with the drive gear in the trans by the sounds of it.
Can you look in the hole with a mirror and a light and see if the drive teeth are damaged and/or missing?
You can buy a new drive gear, but you have to pull the transmission and disassemble to replace;(
Old 09-20-2018, 04:21 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,085 Likes on 1,778 Posts
I don't if you would need to pull the trany or not but the drive gear should be on the out put shaft.
You might be able to pull the drive shaft & tail housing and get to that gear.
I would check with a trany shop to see what they say if it can be done like I said above or need to pull like Rembrant said.
Dave ----
Danny Stroup
09-07-2015 02:47 PM
Alcaeus
08-04-2010 07:19 PM
kona56
04-05-2010 02:13 PM
The_SnowMan710
12-20-2007 02:06 PM
cdherman
10-07-2003 07:25 PM
Quick Reply: Speedo no bueno
