Oil change light less than 2k miles
So I got my oil changed 1800 miles ago and the change oil light already came on....this is a first. It’s been around 5k miles in the past. 2017 6.7 SRW...Mileage is at 19466 right now. Curious if anybody else has had this happen? It’s been light duty with no towing...most weight it’s had is the groceries haha
thanks,
Dan
thanks,
Dan
It was reset. It was going off when I dropped it off to get it changed in June. It hasn’t dinged until now...just curious how it coulda burned through 2 gallons of oil already? Or is it possible it wasn’t reset all of the way?
on your screen in front of wheel move all the way over to settings, go to advance settings, select vehicle, select oil life reset. This will show you percent remaining/and that's also where you reset it within that screen by pressing and holding. Vehicle must be stationary to do it.
I’ll check it out this morning.
Is the oil life % something that has to be turned on in FORSCAN? The only way I can see my % is in the FordPass app.
tjshanahan
2017+ Super Duty
01-14-2018 09:49 PM
tyguy
18
03-07-2005 04:42 PM
