Will a 370 Flywheel work on a 1996 460?
Was chatting with my buddy about the POS E4OD in my 1996 F250. Would love to put a ZF behind it but they want big money for a good one. So we thought what could we piece together. One piece needed is the flywheel and he thought since the 1996 460 was externally balanced and the 1980's 370 was externally balanced it might work. What are your guys thoughts?
I’m a little confused what you are doing. You have an E4OD that is supposedly junk although you haven’t said why or what trouble shooting you have done so you want to replace it with a ZF but they are too expensive. Then you ask if the flywheel from a 370 would work on a 460. Is the balance and tooth count the same for both engines? RockAuto has a brand new Luk brand flywheel for $100 but why would that matter if you aren’t purchasing the transmission?
bigdan1979f-250
02-21-2010 07:24 AM
foggy_2
04-25-2002 02:42 AM
