Turn signal switch not fitting?
I just installed a replacement switch from Dennis Carpenter. This video was a bit helpful:
. Everything lined up correctly, the metal post on the lever side is inserted in the hold on the column, and the small hole in the plastic fit over the pin. The problem is the lever hits the column and can't push it down enough to make the left turn signal light up. Am I missing something, or it just a poor fitting part? I really don't look forward to having to take it out again. See attached pic, when turn signal is OFF, it is almost hitting the bottom. Last resort I could grind a bit of the opening.
D0TZ-13341-B .. T/S Switch / Obsolete/Reproduced ~ Genuine Ford available NOS
1969 F100/350 from serial number G30,001; 1970/72 F100/350.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 3 = 763-434-0123.
MILLER OBSOLETE PARTS in Binghamton NY has 3 = 607-722-5371.
RPN PARTS in Erie PA has 8 = 888-864-9305.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1,302 = 800-476-9653. You have to ask for genuine Ford, otherwise you get made in China repro's.
I don't think there's really much that can go wrong with installation that would cause this problem. The switch only fits one way with the small screws that attach it to the column flange. The piece that the lever screws into only fits one way in the switch. Only thing I can think is the threaded hole the lever screws into is misaligned?
OP, look at the wiring on your old T/S switch for an engineering number sticker. Post what numbers are on that tag. Example would be D3TE13B302AB.
shty150
03-16-2016 05:54 PM
eminencefront
10-01-2014 10:28 AM
thunderbirdcakes
09-24-2012 12:26 PM
