I need this part!
I need this part!
Hi all,
I need a plastic trim piece for the front drivers seat. The piece that has the lumbar support switch on it. I have the 40/20/40 split bench, without power. Mine is broken and I tried gluing it with little success. My interior is opal gray. If anyone has one, let me know. Thanks.
it looks like this, just gray-
So I'm facing similar issues with the plastic failing on my truck. For now have you tried epoxy? That seems to last the longest. The trick is to be sure your part is super clean. Then you might want to contact your local bone yards and see if you can get on a call list. IOW they'll contact you if the part shows up on their systems. They are all on a shared system. Also if you have a Pick A Part or equivalent, you might get lucky. No after market stuff along those lines. Only dashes and door panels. Good Luck!
Well the part that broke off is the forward most hole for the trim screw. It was already cracked when I got the truck, but I accidentally kicked it getting out of the truck after work on Saturday and broke it completely. It's not a really clean break eaither, the pieces didn't fot together very well. But I cleaned them up and first tried cyanoacrylate glue, or Super glue. That held until I sat on the seat. Then I tried using JB Weld and it peeled off like I put it on wax paper, it just didn't stick at all. Now I spent some more time roughing up the surface and cleaning the pieces and bought a tube of JB "Plastic Bonder" Epoxy at Home Depot and I'm trying it. I glued the pieces together and put them in a vise to clamp them with some pressure. Maybe it'll work. If it doesn't, I'm just gonna leave the piece off until I find a replacement. I've checked the pic a parts and came up empty.
Hi all,
Doesn't help you now, but I'm pretty sure most of the interior trim is ABS plastic.
I think a clear ABS cement would be superior when joining broken pieces back together.
Epoxy and screen on the back side, after roughing up the surface would make for a good reinforcement of the cracked area.
KsCop
31
02-27-2014 12:54 PM
