Upgrade wipers
UPDATE:
Was not able to purchase the 24" wipers for my truck, because the local store was out. Decided to keep it stock length and bought 22" RainX Latitudes. The removal and install was (of course) simple...and literally took like 4 minutes. But, I did notice that these Latitudes flutter while driving down the road...starting about 50 MPH. I'm not keen on that...and it's been bugging me!!
Thinking, I'll just go back to my OEM and get refills. Luckily, I did not toss the OEM wiper blades!!
biz
biz
I just put some Motorcraft blades on. The same as OEM. They are better than all the other ones I’ve tried to include Bosch Icons, Rain X Latitude, Michelin and PIAA.
The PIAAs were the best of the aftermarket bunch. I got almost a heat out of them before they started skipping and chattering. All the others made it about 2-3 months. The original factory blades never chattered, they just lost wiping performance after about a year, which is pretty good down here as hot as it gets.
I have found that just about everything OEM is better than over the counter aftermarket. It is also the reason why I only use Motorcraft filters. I have found nothing beats the performance and plus the fact that it helps if there is a failure under warranty. Ford won't question the fact about an oil filter failure when you use their filter. I always do my own maintenance from day one and have never been questioned when taking my vehicle in for service.
