2000 Ranger will not start
2.5L 2WD automatic - Went to work this morning no problems, at the end of the day ready to leave and truck would not start. Appears battery is fine all accessories radio lights working etc.. turn ignition and and one click but engine does not turn over. First thought is starter solenoid. Does that sound right? Is there anything I should do before I pull the starter? Thanks
You should check all fuses/relays associated with the starting system and ignition system first. Look in your 2000 Ranger Owners Manual under the "Roadside Emergencies" section for diagrams and descriptions of the fuse/relays in the Passenger Compartment fuse panel, as well as the Power Distribution Box located under the hood.
If you want the long version of testing automotive relays, then do an internet search, there are some very good videos on that subject. My way of testing them is to swap in another relay that is known to be good.
You mentioned you checked the starting system fuses, how about those associated with the ignition system?
Another thing to think about is the ignition switch itself...sometimes they can fail at the key/column area. Have you tried starting it in neutral?
Somewhat related to that, does your Ranger have PATS ("passive anti-theft system")? They are usually quite reliable but problems can occur. See for example https://www.cargurus.com/Cars/Discussion-t1359_ds35945
I can't recall right now if our vintage Rangers have a stand-alone starter solenoid, or if the solenoid is integral to the starter itself...hopefully someone will chime in and confirm.
Some food for thought, hope it helps.
Plug in your ELM scantool into the in cabin DLC port & running FORScan diagnostic freeware on the viewing device of your choice as discussed here https://www.ford-trucks.com/forums/1...-scantool.html, as its tweaked for Fords & can scan All of the onboard computer/controllers, including the PATS anti-theft system for trouble code clues that can help focus a trouble shoot, then post All code Numbers.
For no cost Wiring & TSB info, enter your vehicle particulars & click on wiring diagrams here BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
As Rockledge suggested, check the starter relay as they are a common problem part. It's in the under hood battery junction box, driver side, back against the firewall/fender location. Give the relay a wiggle/thump test to see if it'll wake up, or swap it with a known good relay as Rockledge suggested.
If still no joy, perform a wiggle test on the wiring to the starter motor & or give it a thump test with a piece of wood & see if it'll wake up.
More trouble shooting thoughts for consideration, let us know what you find.
If you can feel the starter solenoid pulling in, then thump the starter motor with a piece of wood & see if it'll wake up & run. If so, suspect the solenoid high amp contacts that run the starter motor are eroded & making poor contact, or maybe worn starter motor brushes, or starter motor commutator is worn, if a thump will make it wake up & run.
As Rockledge suggested, check the starter relay as they are common problem parts. It's in the under hood battery junction box, driver side, back against the firewall/fender location. Give the relay a wiggle/thump test to see if it'll wake up, or swap it with a known good relay as Rockledge suggested.
