2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Advice on Tire pressures
Old 08-20-2018, 08:29 PM
Rtr2017!'s Avatar
Rtr2017!
Rtr2017! is offline
Hi,
Picked up 19’ F350 and factory tire settings were 60psi front , 80 rear.
From hauling before, I understand 80psi is what you safely need under a load.
But for day to day driving, is 60psi all the way around ok? Will it cause the tpms to give me warnings?
The ride is noticeably smoother in the front with lower pressure.
Thanks for any help and advice. I appreciate this forum.
Old 08-20-2018, 09:09 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
It might, depends on your TPMS settings. I used Forscan to modify my alarms to under 60psi all the way around. Mines a diesel so I am running 65 psi all the way around. Seems to be the separate spot when empty for me. When towing, my trailer isn’t that heavy so usually air up towing to 75 PSI rear. Fronts stay the same. When I hauled my buddies heavier enclosed car hauler, 80 PSI rear.
Old 08-20-2018, 09:22 PM
kho6658's Avatar
kho6658
kho6658 is offline
I run 60 front and 72 rear. Anything lower than 70 will set off the alarm.
Old 08-20-2018, 09:48 PM
Rtr2017!'s Avatar
Rtr2017!
Rtr2017! is offline
Thank you all for the feedback. Looks like the rear will be just above 70 to keep the alarms off.
Old 08-20-2018, 09:54 PM
Mr. King's Avatar
Mr. King
Mr. King is offline
Here’s What’s Working for Me.
I have done quite a bit of experimenting with the tire pressures on my 2018 F350. Blanche has the 6.2.
I run 60 psi up front and about 63 out back. My TPMS light comes on at 59 psi on the rear. I run 63 to allow for cooler temps when she sits at night.
if it really cools off I have to play the game to get the light to turn off and then back down to 63.
Mr. King
Old 08-20-2018, 10:19 PM
N2dunz's Avatar
N2dunz
N2dunz is offline
I base my tire pressure on CAT scale weights and load inflation tables from the tire manufacture.
Fronts are 65.
Rears are 40 when not towing and 58 when towing.
I don’t care about the TPMS alarm.
I have a 2019 dually.
Old 08-20-2018, 10:37 PM
Txfoster's Avatar
Txfoster
Txfoster is offline
I have a 19 dually as well and like running 40 out back unloaded.
I've used forscan plenty and am fimiliar with it.
Does anyone know the settings for the Dually pressure's?
Old 08-21-2018, 01:02 AM
hobbie1's Avatar
hobbie1
hobbie1 is offline
I have 2018 F250.
Truck is a 2018 Lariat 6.7 Diesel crew cab with the 6'9" bed - FX4 package - 20" factory rims & Michelin tires - 8600 mile on the OD.
What we have done:
1. Installed FOX 2.0 Performance Series IFP shocks Front # 985-24-154 Rear # 985-24-151
2. Installed FOX 2.0 Performance Series Stabilizer IFP # 985-24-00
In the quest for the best possible ride - I called Fox....
Per the tech support recomendation - Did the following:
Set the stablizer to 45LBS to deal with the slight drift to the left
Front tires aired to just below factory specs - cold 58LBS
Rear tires - drop them down - cold PSI 53LBS - My son used his shops programmer and set the rear air threshold to 50LBS left the front at the factory setting to trigger the TPMS alert light.
Ride is the best ever. Fox tech also said to give the shocks some time to break in and they will improve.
Hope this helps.
Old 08-21-2018, 07:44 AM
Shoester's Avatar
Shoester
Shoester is offline
Fronts are 65.
40psi on the rears?! I have a 2017 F350 dually...I get antsy below 65 in the rear.
Old 08-21-2018, 08:07 AM
jergle's Avatar
jergle
jergle is offline
It's always interesting to read these posts and see that apparently everyone's TPMS is set differently. My 2017 F250 SRW has not been changed from factory settings (unless the dealer did it before I bought it), and I run 55 psi front and rear unloaded, and have not set off a warning light. Is there a "standard" factory setting, or does it vary from one truck to the next?
Old 08-21-2018, 08:13 AM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Originally Posted by Rtr2017!
Hi,
Dually or SRW?
If a SRW there is no problem at all with running the rears at the same pressure as the fronts, unloaded. I run mine at 60 psi all around unloaded and the ride and wear are much better. When I am towing I set the rears at the factory spec.
Old 08-21-2018, 08:18 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Received 2,176 Likes on 680 Posts
My truck calls for 70psi fronts and 65psi rears....I usually drop down about 5psi front and rear for daily use...towing I'll go to the 70 in the front and 65 in the rears. DRW with 15K miles and hardly any signs of tire wear.
Old 08-21-2018, 09:05 AM
F350FordToy's Avatar
F350FordToy
F350FordToy is offline
I do the same thing, drop 5psi unloaded.
Old 08-21-2018, 12:21 PM
bitNine's Avatar
bitNine
bitNine is offline
In my 2013 Ram 2500, it actually had a switch for the TPMS system that would allow you to do light/heavy load situations. It recommended 65 front, always, and 45 for light load with 75 for heavy load. When I got my 3500, recommended pressure was 80psi, but it did not have any warning system for pressures, so I would still air down to 45psi.
Someone here mentioned the chalk test the other day, and that's probably the right way to test. Something like draw a chalk like across tread on width of tire, drive straight lines forward and back. Check chalk line. If chalk if wiped off of center, but not outer tread, then you have too much air for the current load.
Old 08-21-2018, 12:28 PM
SecondChance's Avatar
SecondChance
SecondChance is offline
When I had a single-rear-wheel truck with the same pressures on the sticker, I had the same question. I call the dealer and was told not to reduce the pressure in the rear tires when empty - run them at the specified 80 PSI. I don't know if this answer was driven by the TPMS parameters or not.
Rob
FONRDAY
2017+ Super Duty
20
01-08-2019 09:47 AM
Deagle12
04-07-2018 03:33 PM
Rustyfan21
2017+ Super Duty
02-09-2018 04:32 PM
ysgi
2017+ Super Duty
12-28-2016 05:24 PM
crapr6
16
06-21-2007 12:45 AM
Quick Reply: Advice on Tire pressures
