TorqShift-G (6R100) Tranny Sanity Check
Been a few reports of odd shifts. But no major issues. The transmission in base (ZF HP26) form has been around for a long time and the real issues were worked out long ago. Stay within limits of it and you will be fine.
Received 6,629 Likes
on
on
I've noticed the clunk sound/feel mentioned above when reapplying gas and traveling at ~25mph and its in 4th gear. More like U-joint. My 2002 had similar issue but it had 125k vs 14k.
I have also noticed on rare occasion when shifting to reverse more noise than I would expect.
Exactly like described in this thread:
https://www.ford-trucks.com/forums/1...ine-clunk.html
When letting off the gas or suddenly re-applying it, frequently causes a "Clunk" to be heard and felt below the truck - best way to describe it is slop in the drive-line somewhere. Seems to be almost exclusively reported by those with 6.2/TorqShift-G.
Thanks for sharing the thread. I hadn't seen that one. It does seem related more to TorqShift-Gs but not exclusively. It almost seems related more to Sterling rears as there was a few F250 6.7s in the thread. They'd have 6R140 trannies but most likely have the Sterling rear vs the Dana rear.
