LED Turn Signals
on
Is it just your LED turn signals? If the are cheap lights, they may have a chip problem.
I would put the stock bulbs back in, verify there is no issue, then try another LED manufactures lights.
The other possibility is you have a load on the turn signal circuit that’s causing it. But you should see it with the OEM lights also.
