6.2L V8 Discuss the 6.2L V8
Need a recommendation on an oil drain pan
Old 08-14-2018, 11:48 AM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
What are y'all using.
My 6.2 takes seven Qts, my daughter's 5.0 eight Qts, my wife's 5.4 sumpin like the others.
My little drain pans are about to be retired just now I had to have my wife kick the other one to me to switch out one that almost overflowed while I was under the car.
Old 08-14-2018, 02:38 PM
ibdagriz's Avatar
ibdagriz
ibdagriz is offline
FloTool 15 Quart Drain Container
Advance Auto. $10.50
Griz
Old 08-14-2018, 05:49 PM
82_F100_300Six
Thanks Griz I just got these two cheep ones from Advance
I like the open concept and I like to have a separate one for the oil filter drain.
Old 08-15-2018, 09:46 AM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
Whatever 5 gallon gas can you can find on sale. Magnitudes easier to store without spilling and take in for recycling...plus with your fleet, you can probably fit everything into one container after an oil change.
I have a 15qt plastic pan that just gets dumped into the 5gal used oil gas can. Makes life so much easier than keeping oil in a flimsy pan.
Old 08-15-2018, 11:40 AM
82_F100_300Six
Thanks Saratoga yeah life is a little easier not owning two diesels anymore at least the waste oil takes a little longer to fill up my container. Then I call ahead to see if the parts house waste/recycle tank has room in it for me to come dump mine.
Old 08-15-2018, 09:08 PM
leadmic's Avatar
leadmic
leadmic is offline
My truck is a 2011 4X4 and I use a 5gallon home depot bucket. It fits perfectly.
Old 08-16-2018, 03:44 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
Old 08-16-2018, 09:45 AM
ibdagriz's Avatar
ibdagriz
ibdagriz is offline
I will admit I did stick my hand into the drain to make sure it was open on the one I have after pulling the drain plug.
I have never seen one open like that and I shop at Advance too.. LOL..
Griz
Old 08-21-2018, 10:14 PM
minke's Avatar
minke
minke is offline
Old 08-21-2018, 11:37 PM
82_F100_300Six
I like that. Looks like good quality. Thanks
Old 08-25-2018, 06:55 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,736 Likes on 1,329 Posts
5 gallon bucket for me. Might not work for cars....but I don't own cars
Old 06-13-2020, 06:51 PM
Flyct's Avatar
Flyct
Flyct is online now
Wrong forum
Old 06-13-2020, 07:43 PM
Lamoon78's Avatar
Lamoon78
Lamoon78 is offline
I have something similar from Tractor Supply
Old 06-13-2020, 08:57 PM
minke's Avatar
minke
minke is offline
It can be a handful to dump! I am still using it.
Old 06-14-2020, 02:53 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Quick Reply: Need a recommendation on an oil drain pan
