Keep Blowing 20amp Maxi Fuse
Got a '94 7.3 IDI with aftermarket turbo that's developed this annoying habit of blowing the 20 amp Maxi fuse responsible for the glow plug circuit. I can replace the fuse and get a few starts out of the truck before I no longer get the WTS light.
GPR was already on it's way out, so I've replaced that. Measured glow plug resistances and got some variations ranging from .7Ohms down to .2Ohms. I don't trust my digital multimeter due to the fluctuations in static resistance between 0 and .3Ohms. However, will measure again.
Does anyone have access to a wiring diagram specific to the glow plug circuit so I can begin tracing wires and checking components? Can glow plugs out of wack cause such voltage fluctuations to pop the fuse over a matter of hours?
Received 3,106 Likes
on
on
hmmmm.. just a thought. try disconnecting the fuel heater on top of the fuel filter housing, tape the wire end off, and put a new fuse in to see if it works.
if the fuel heater shorts out it will blow the fuse and cause issues. i don't know the 92 and newer trucks that well, but it may be something as simple as a bad fuel heater element.
mine on the 88 has been bypassed since 1990.
on
on
Please stop putting bigger fuses in unless you want to be redoing the entire engine wiring or burning your truck down....
That fuse only feeds a few things on the engine, I would start by disconnecting the fuel shut off solenoid, high idle solenoid, cold timing advance solenoid (all three of these are on the injection pump) glow plug relay and the thermal switch behind the thermostat housing, that will isolate everything on that circuit and you can start plugging stuff back in till your fuse goes and that will be the offending part.
Note: the high idle and cold timing advance only get power when the thermal switch is below 120F, you may be better off getting a fuse holder and a few pieces of wire and testing those off the battery.
I'm seeing lots of solenoids, wondering if one is sticking. I'll attempt to test and isolate the parts.
What's odd is that I get a few cycles out of the gpr when attempting to start the truck before the fuse eventually blows; it's not a case of where you put in the new fuse, turn key to on (or start), and the fuse pops right away. A sticking solenoid could be causing the problem after prolonged starting attempts.
I'll check it out in the morning. The diagram I found from the tech thread here has those parts listed. Any suggestions on just testing each individual solenoid by applying power through a fused connection?
So far, minus testing the cold timing advance solenoid and the thermal switch straight to the battery, the tests have proved inconclusive. I tried with the starter circuit 20A fuse out of the way so I could better see the condition of the fuse, turning the key to the ON position and connecting each component one at a time while examining the fuse after each plug in. I repeated the same tests with the starter circuit fuse in place and got the same results. Fuse still OK.
I've not tried to start the truck yet, but will be doing that shortly after checking all wiring once more.
I'm not entirely sure what could have gotten messed up when the filter leak was addressed, which is why I wanted to do that myself as the truck started and ran fine before that. It's been hard to start for years, but always started and never blew any fuses before. Could the stress of repeated starting attempts be causing the fuse to begin "cooking" slowly before it just gives up the ghost and pops?
I tested the plugs again and get a consistent reading across all between .5-.7Ohms (cold, obviously). Much wiring is hidden under wrapping as well as wire loom tubing, but none of it shows signs of heat damage. At a loss here. This really came out of nowhere after the filter housing leak was addressed. Fuel heater remains unplugged and I disconnected the "Water in Fuel" sensor just to be sure.
With a fresh fuse, WTS light comes on for 8-10 seconds, so nothing unusual there. I will try cycling the key between off and on a few times to see if the fuse will give out; I'll know when the WTS light no longer illuminates when the key is turned to ON.
