Old man exhaust..... what do you use?
Ok. My truck has 2.25" duals, leaking manifolds and glasspacks...
i can't take it anymore. So I am starting to look into an entirely new exhaust. The truck has a rebuilt 390 that runs great, but still sounds like a dump truck. My thought is to run either new manifolds or shorty headers and 2.5" pipes to a 2 into 1 muffler with a single 2.5 or 3 tailpipe.
Thoughts on manifolds vs shorty headers and thoughts on what muffler you would run? If I can hear the truck, fine. But I don't want it to drone and I don't want it loud. its a 1975 highboy btw.
Thanks!
Shane
Thanks!
Shane
Headers for a highboy pretty much don't exist last I checked. You can't use 2wd headers and headers for a half ton don't fit either. Last one I did because like you I couldn't take the noise anymore. I did 2.5 from the stock manifolds into a X pipe then I did a flowmaster 70 series dual inlet and went out with 3inch and a flowmaster hush resonator and exited behind drivers tire. It fit the bill for what I wanted, word of warning it was so quiet I often thought it stalled while in traffic.
When I put the rebuilt 400 back in my truck I went with new headers (I believe Hedmans) because both of the stock manifolds were cracked. The headers were actually cheaper than the repop manifolds and breathe better. Added some Dynomax mufflers that are relatively quiet but have a nice tone. You have to make sure you get the correct headers for your front end to have the proper clearance. The truck sounds good with no leaks. My truck is a 78 F250 4x4.
Due to a clearance issue with full headers mine has shorty headers. 2.25” duals that dump in front of the back tires. If you want the exhaust to have some throat down low, go with a Flowmaster. If you want a smooth flow down low go with a Turbo style muffler. I have Dynomax turbo style and it’s entirely too throatless for me.
Personally I would keep the duals... just need a quieter muffler and manifolds that don't leak.. A generic stock replacement muffler similar size or bigger to what you have would quiet it down a bunch. Or a turbo muffler which is pretty quiet cruising and has some bellow when you get on it.
Adding an H pipe to connect both sides of the duals near the front will also quiet id down some and also improve performance.
No headers for highboys.... does this include the shorty headers? I imagine the longtubes would not fit. But some of the shorties look like they exit about where the manifolds do. No?
https://www.ebay.com/i/232841054800?ul_ref=https%253A%252F%252Frover.ebay .com%252Frover%252F1%252F711-198453-24755-9%252F16%253Fmpre%253Dhttps%25253A%25252F%25252Fww w.ebay.com%25252Fi%25252F232841054800%2526itemid%2 53D232841054800%2526tag6%253D232841054800%2526tag7 %253D0%2526tag8%253D23842971210670601%2526audtag%2 5253D1_103_2%2526tag4%253D23842971211650601%2526sr crot%253D711-198453-24755-9%2526rvr_id%253D1606634594408%2526rvr_ts%253Dc371 807e1640ac800691af70fffcbd6b
I was in your boat. Just took ownership of my dad's '77 Highboy and literally the day I got it, the tail pipe fell off from rot. Being in the Denver metro area, emissions are required on '76 and newer, they wouldn't even test it with the missing tail pipe.
I went to a local shop and had them custom fit a true dual system from the manifolds back, using Flowmaster Series 40's and I absolutely LOVE those cans. I get compliments and thumbs up literally every time I drive it. No, it's definitely not quiet, but certainly not obnoxious by any means. Very healthy rumble at idle, and surprisingly quiet and drone free at highway speeds. If needed, I'd put the exact same system back on. Cost was $450 total, which you can't beat.
As for headers, I found nothing after market, except for Headman's, but heard numerous negative reviews about them. Everything from fitment issues, to warping issues, to rusting issues. The deciding factor tho was that there was very little proof that they even help boost performance. But, I'm running a 351M which from what I know isn't a very tunable motor, so take it for what it is....
https://www.ebay.com/i/232841054800?...91af70fffcbd6b
Headers for Ford, Mustang, Pinto, Bronco, Cougar, Ranger, exhaust parts for home built do it yourself automotive headers.
