Sponsored by: Halo Lifts
500# over Payload Rating
Old 07-22-2018, 11:54 AM
Foamster's Avatar
Foamster
Foamster is offline
I am preparing to order a 2019 Truck. I prefer to order a 2019 F-150 Regular cab equipped to have a payload rating of 3,000#, which with my 3,000# camper (wet) will be about 500# over Payload Rating with 2 persons and gas. I hope to replace the camper with a lighter rig within a year so how fragile is this situation if I am extra careful for that year?
Yes, I could get an F250 but the ride will be inferior for the life of the truck, and I prefer not to buy two trucks. Please share your opinions on how much risk is involved. With air bags the camper should ride level, but how “floaty” would it be?
Old 07-22-2018, 12:12 PM
tomfiii's Avatar
tomfiii
tomfiii is offline
Is that the trailer tongue weight or whole trlr weight?
Old 07-22-2018, 12:21 PM
Foamster's Avatar
Foamster
Foamster is offline
No trailer, a truck slide-in camper. Sorry, I did not make that clear. I thought payload implied a truck slide-in camper, but now it's obviously misleading. I do not intend to tow, certainly not with this camper in the bed.
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
I don't think he's talking about a trailer. I think he means a camper that sits in the bed.
My opinion is that it probably depends on how many miles, and what kind of terrain you intend to drive on.If you're going 10 miles on smooth pavement, then NBD. If you're going 10,000 miles off-road, there would probably be issues. There's a whole lotta space between those two extremes.
Old 07-22-2018, 12:41 PM
Foamster's Avatar
Foamster
Foamster is offline
Ok, realistically a trip would involve 700 of miles of interstate to Utah, then 150 miles of off-road including some that could be at the limits of a factory vehicle, then hundreds of miles asphalt highways to Death Valley, then 100 miles of washboard, then hundreds of miles back to LA. Or maybe LA- interstate to Montana, then fire roads for a month, then interstate to LA. So minimal off-road at an extreme, but a few hundred miles of unimproved roads. How comfortable would you be in a vehicle at/over the limit.
Old 07-22-2018, 01:24 PM
Lebowskii's Avatar
Lebowskii
Lebowskii is offline
The truck should be able to handle 3000 pounds with no problem. I've hauled more than that in the back of my truck several times including 6000 pounds of topsoil once for a couple of miles. I say go for it....
Old 07-22-2018, 01:30 PM
EB-Larry's Avatar
EB-Larry
EB-Larry is offline
Keep in mind that any options on the truck will cut into your payload. You can find out the weight of the options then subtract them from your payload. I bought a 2018 F150 CC that should have given me a 2100 lb payload. I checked the payload sticker and it was actually 1590. Someone on here gave me a link to the option weights and when I added them up and subtracted them from the theoretic payload it came out about right. I would not put a 3000 lb camper on an F150 that even equaled my payload. I would say F-250 or F-350 with a real 4000 lb payload.
I's like the trailer capacity. I have a 6000 lb trailer but wanted a tow rating > 10000 lbs. Mine comes at 11,500.
Old 07-22-2018, 01:35 PM
EB-Larry's Avatar
EB-Larry
EB-Larry is offline
How often will you carry the camper? If very rarely not a problem. If left on the truck all the time I foresee wheel bearing replacements.
Old 07-22-2018, 01:50 PM
Foamster's Avatar
Foamster
Foamster is offline
Camper is full time, but less than 10,000 miles per year, and I hope to replace it with a lighter camper in 12-18 months. Wheel bearing would be cheap if that was the only problem.
Old 07-22-2018, 02:22 PM
scott91370's Avatar
scott91370
scott91370 is offline
For payload you do not count the weight of fuel and there is also 150# allotted for the driver weight. This should, in theory bring you down 300# (depending on gas tank size, could be another 80#) - leaving you at only 200# over. I would venture to say engineering wise you'll be ok. Depending on if you get stopped & weighed is another story.
As far as the ride with airbags, I would guess it depends on the bags and psi. I run Airlift 2000. While I don't run anywhere near the payload with my trailer it doesn't bounce when towing even when aired up to 90psi (max is 100).
Old 07-22-2018, 02:44 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
To the above, how do you figure you don't count fuel? Also how do you figure the 150 lb alloted driver? Its not overly complicated, just take it to a weigh station and get curb weight. Subtract curb from GVWR and you get payload. I will say we have plenty of RCLB trucks at work and none of them have a 3000lb sticker from factory. I believe you have to order the heavy payload package to get it.
Old 07-22-2018, 03:09 PM
Foamster's Avatar
Foamster
Foamster is offline
According to Ford's brochure a 4x4 with 3.5 Ecoboost & HeavyDutyPayload and 18" wheels has a payload of exactly 3,000#. I thought I needed to subtract the weight of my wife and I (300#) and a tank of fuel (about 200#). That would put me 500# over...are you saying that is not the correct calculation? It would be fantastic if I was only 200# over. I can't use a weigh station because I am trying to decide whether to buy an F-250 or a smoother-riding 150.
Old 07-22-2018, 03:23 PM
smokewagun's Avatar
smokewagun
smokewagun is offline
Psyloads posted on the B-Pillar ALWAYS account for full tank of fuel and a driver weighing 150#.
ANYTHING beyond that comes off the remaining payload on the B-Pillar.
Old 07-22-2018, 03:27 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Generally speaking, "dry weight" does not include fuel or passengers. So those need to be added to the payload.
Old 07-22-2018, 03:35 PM
NAZSD's Avatar
NAZSD
NAZSD is offline
I’d be concerned about the brakes with that load on an F150. Consider mitigating this with slower speeds and heavy duty brake pads. Also, tires may need to be in the load E range.
Add air bags and/or a Big Wig anti-sway bar if the sway is not tolerable.
For reference, I have a 2017 F250 Gas CCSB Fx4 with a 3000 lb camper. 11,000 miles with the camper last year and have spent considerable time thinking about an F150 replacing the F250 in order to have a more comfortable DD.
Quick Reply: 500# over Payload Rating
