Checking fuel pressure 6.2L
Hey guys, dealing with an ongoing issue with 2 dealerships that refuse to honor their warranty on my truck. I have an extended crank issue that I believe to be a bad check valve in the fuel pump, but the dealer refuses to look any further at it because they have been unable to figure it out. Is there anyone that can tell me how to check the fuel pressure on the 2017 F250 6.2L? I have a pressure gauge and a shop full of tools, but I am used to working on much older vehicles. Is there a schrader valve somewhere that I’m missing?
It never fails when I'm in a crowded parking lot, gas station, or my neighbor is standing in their driveway it does the long crank and I get the "wtf, isn't that a brand new truck" looks. Maybe only once or twice in the two months and 3,500 miles has my truck done it on the fist start of the day, almost always on subsequent starts.
Same issue here. From reading in other threads I suspect it to be bleeding off fuel pressure after shutoff due to a bad check valve. The dealer has given up on it so that leaves me to do the “professionals” job.... Sadly the truck is still within warranty, but that means nothing to the dealer who refuses to honor it.
Dealer just called, my truck will be ready tomorrow. And they couldn't duplicate the intermittent long crank (again).
I really like my 2018 F250. This is the one issue that truly disgusts me though. I honestly dread starting the thing because it just sounds unhealthy when starting, even when it doesn't do a full long crank.
Did anyone ever come up with a fuel pressure test port on these yet?
Im looking a for a port just to get fuel out of it for the fuel pump replacement. My symptoms are stumbling, long cranks and lazy starts. Im gonna just replace the fuel pump, and not even deal with a stealerships nonsense on this one.
TXCOMT
I don't know where the service port is for the system, or even if there is one. You can get a fuel pressure reading by scanning the data stream.
If you do believe system pressure is bleeding down, there is a simple test you can do that requires no tools or special diagnostic skills. Cycle the key a couple times without attempting to start the engine. Turning the key to the "RUN" position energizes the fuel pump and doing this twice ensures fuel pressure is at the rail while cranking.
If the situation occurs more frequently on restarting a hot engine, you could be dealing with a flooding condition. In that case, it might be easier to start if you first put the throttle pedal down about half way, then crank. Adding throttle while cranking shuts off the fuel injectors and gives the engine extra air to help clear the flooding condition.
If one of these works for you, you now have a data point to talk to the service technician about.
Have the dealer read through this thread.....
https://www.ford-trucks.com/forums/1...-starting.html
I have the same long crank issue. I can pretty consistently reproduce it if i drive the truck 10 - 15 miles then let is sit for four (4) hours. There is usually a long crank after sitting that long give or take an hour. But If i let it sit longer it does not seem to happen or happen as much. Most (98%) morning it's fine.
I have looked in the logic of how the fuel system works and trying to make sense of why this happens. From what I can tell the fuel system is a single line system (there is no return line from the engine bay, maybe it still considered a return system since there is a regulator at the tank). I am not sure if the regulator is the type that limits the pressure upstream by bleeding off excess pressure in to the tank or not. On start-up the ECM checks the fuel pressure and tells the fuel pump control module to turn on the fuel pump to a certain speed. From what I have read it seems like the speed of the fuel pump is usually double of what the demand of the engine requires. I got this from reading though some of the files here: https://www.motorcraftservice.com/freeresources/obd. There is a chance that my understanding of how the system works or that it's the same for all Ford natually asperated gas engines.
For those that have had the fuel pump replaced it seems to fit it. Can anyone confirm if its the pump, check valve, regulator,fuel pump control module, etc? When the "fuel pump" is replaced has it been the entire fuel pump assembly? Does the fuel pump assembly include the regulator?
- A bleed down in pressure should not be an issue, unless the bleed off is so large that the pump can't keep up. But i would think an error would be thrown.
- Maybe the pressure reading from the fuel pressure gauge are off. This should be easy to check to see what the ECM says and what a manual gauge reads
- Maybe the pump is marginal in the flow and pressure it is putting out. At low speeds and on start it takes a few seconds to catch up? I would thing there would be a low fuel pressure code.
Same symptoms here...I've got a date with Grapevine (Texas) Ford on Wednesday to take care of two recalls and the lazy start issue. Sure hope it's a pain-free experience; thankfully here in Dallas-Fort Worth, we've got a plethora of Ford houses. Surely one of 'em near me can fix this as I really don't want to swap pumps myself.
TXCOMT
TXCOMT
Priceless info right there!! Thank you!
Fred377pine
11-05-2018 06:58 AM
bmxerbrett
21
05-15-2016 03:04 PM
