1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
regen stopped at 70% ???
Old 07-18-2018, 05:25 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
This is a '16 F350 King Ranch dually with 14,135 miles on it, has been absolutely trouble free. Driving down the road 2 days ago she went into regen, when it got down to 70% it just didn't go any further. I drove it an extra 15 miles but that was it. I called Ford service and the guy said .....just keep driving it till a check engine light comes on or something else pops up on the screen. Well that doesn't suit me too well so has anyone else had your truck do this? thanks, Dave
Old 07-18-2018, 06:13 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Did you stop for a extended red light? If you stop for a few minutes at a red light, it might stop the regen. Any other reasons you dropped below 4mph for extended period of time?
Old 07-18-2018, 08:05 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
Nope, was on the highway at 70 mph the entire time.....thanks
Old 07-18-2018, 08:11 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
it is strange that you did not put it in park or shut it off.
I don't know of any other condition that would of canceled the regen.
Scan for any codes?
Old 07-18-2018, 08:47 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
Yea I was stumped and so was the Ford dealer service guy. Going to take it in anyway Friday and have them take a look. The only other thing is that it ran out of DEF but it never flashed any codes on the info center. I don't drive it very far very often so DEF last a long time, thanks for the replys.
Old 07-18-2018, 08:51 PM
senix's Avatar
senix
senix is online now
running out of def would have given you a message and a code, that code would go away after refilling. That would not prevent a regen to the best of my knowledge.
Old 07-19-2018, 05:01 AM
Fefanatic's Avatar
Fefanatic
Fefanatic is offline
I posted a similar issue a few days ago. After turning on the display mine showed 90% and went into a regen a few miles later. I ran it on the highway and it also stopped the regen at 70%. I watched it until it got to 95% and put it on the interstate to do the regen. As soon as it went into regen I got the check engine light. and a P207F code. This time the regen went to 15%. Took it to the dealer and they had it a week until they re-programmed the pcm under TSB 18-2109. I've tried to research the TSB but haven't had any luck on it. Whatever it was my truck seems OK now.
Old 07-19-2018, 09:00 AM
Deuce40s's Avatar
Deuce40s
Deuce40s is offline
Originally Posted by cyncwby
The only other thing is that it ran out of DEF. I don't drive it very far very often so DEF last a long time
What did you do with all the warnings it gave you?
Old 07-19-2018, 11:41 AM
cyncwby's Avatar
cyncwby
cyncwby is offline
As I said earlier Deuce.....it didn't show any warnings or anything on the info center. To Fefanatic, thanks for that info, I'll take that to the dealer tomorrow, maybe that will give them a headsup.
Old 07-21-2018, 10:53 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
Just an update .....went to the dealer yesterday, he ran a quick scan which showed "no codes". He had no explanation as to why it stopped at 70%, said keep on driving it and if it goes into limp mode then we'll have some code to look at. I had to drive down to Saint George, Ut. to pick up my 455 Olds engine block from the machine shop ..... bout 70 miles round trip. Hit the highway and the truck went to 75% then just before I got down there she was showing 95%, I thought ok, it's doing something anyway. On the way back it finally showed full and went into regen until it hit 15%. I'll just have to wait and see if it does the same thing again. Also, the service guy said they could do a forced regen but that would cost ME! Is that normal for a 14,000 mile truck still under warranty?
Old 07-22-2018, 06:46 AM
senix's Avatar
senix
senix is online now
The manual regen would have cost you as there was nothing to lead the tech that it needed to be done. It would not be billable to Ford to cover the tech's time.
Old 07-22-2018, 07:04 AM
Desert Don's Avatar
Desert Don
Desert Don is online now
Received 4,625 Likes on 1,643 Posts
If you don’t drive very far, very often, MAYBE you need to hook to a heavy load once in a while and warm her up good for a few miles......diesels love to be worked!!! I am kind of the same way, but I do pull a light load quite often, and then I hook to the Raptor and make it work several times a year. Not necessarily a long haul with it but at least enough to blow the cobwebs out. Right now at about 42,000 miles....10,000+ pulling the Raptor, about 8000 or so pulling a 38’ enclosed gooseneck, and 6000 or so pulling an 18’ tandem flat with my RZR on it. Never an issue yet.
Street Rail
09-29-2015 08:57 PM
Schlava
6.7L Power Stroke Diesel
07-07-2012 04:37 AM
onelionhunter
01-08-2010 02:50 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
11-21-2004 04:43 AM
gbpfan
07-03-2004 05:17 PM
Quick Reply: regen stopped at 70% ???
