Need new a truck
Need new a truck
I currently drive a 2004 3500 Silverado 8.1 crew cab shining little over 500,000 and had it almost 4 years now. I love my truck it's great towing/pulling our horses and heavy equipment around but it over heats on the grape vine (I do live in California) if I keep rpm high and 2 times it reduced engine power so I was stuck in 90 to 100 degree weather. I'm planning to buy a Excursion 6.8 V10 or the F250/350 v10 heard those are pretty tough engines and better with a 5 star tune for pulling if I'm correct? I don't want to worry about it dying or over heating on me while towing heavy loads up the hill. (I am new to this forum)
If you stick with stock size tires the 4.56 would be good. How much elevation is the grapevine? I finally got to the top of the Loveland Pass Summit in Co. doing 22 mph in 1st gear foot to the floor. The elevation seemed to really kill power. I think that was about 11k or 12k feet.
Gears, gears, gears..............the V-10 needs them to do the heavy towing work well.
My V-10 EX is the dedicated tow rig for our 11,300lb 12' tall TT, I run 35" tire's with 4.88 gears for an effective 4.39 ratio and it gets the heavy work done pretty well. I have never pulled the Grapevine or Loveland Pass but I have topped Fancy Gap at 60 MPH in 3rd gear without having floored it. In the 35K miles I have towed heavy with it I have never seen coolant temps over 210* or trans temp over 208* with the stock cooler.
5Star tunes are well worth it for the improved trans strategy.
Regearing is the answer. The better mechanical advantage from gears is apparent all over the rpm range, not just when revving the V10, which they like to do anyway. I recently drove a 4.30 equipped excursion on stock tires and it felt better than my 3.73 version all over. Gears are in my someday shopping liat
