Tires
Tires
Has anyone used the Michelin Defender LTX M/S 235/75/R15 on their 90 to 95 F150 4x2 and if so how does the truck handle on the highway.currently I have the Michelin Defender LTX M/S P235/75/R15 on my 95 F150 and the truck wanders at speeds above 45mph.I know it's not the front end,it is totally rebuilt including replacing the steering box with a new Mortorcraft one,.Thanks in advance.
An easy check that you can do yourself is to swap the front and rear tires, then test drive to see if it changed at all.
Also, just because it is all rebuilt, does not mean there is not the possibility of a faulty part or bad alignment causing the issue.
This is a very valid point as well, tires can be defective just like anything else.
beem1je
11-02-2013 11:01 AM
snydermotive
09-06-2007 06:27 PM
