Ecoboost issues
Ecoboost issues
So my 2017 F-150 Eco has 78K miles on it, both the timing chain and the turbos are giving me headaches. The timing chain rattles when ever the truck sits for more than a day on the first start. (Ford known problem but won't do anything to help). The turbo's cut out when ever I punch the gas to pass another car or truck, it starts to vibrate, lose power and the check engine light comes on. It's so bad that unless I pull off the road I'm jeperdizing my lift from someone running up my rear and crashing into me.
Is there any class actions going on or has anyone tried to take on Ford to correct the known issues.
Should have never went with Turbo's over V-8
This post reply ISN'T an attempt to deflect your comment but to illustrate that Honda, a very well respected car builder has been dealing with it's own issues on "variable" cam and cylinder management that is causing excessive oil consumption and misfire events in the 3.5L engine due to fouled plugs and failed COP's and failing VCT components.
My stepson has a 2018 Equinox 1.5L GTDI as a company car. Nice vehicle with extreme power and likely best in class MPG's. At 36K miles he needed to have the #2 plug replaced due to a misfire event.
Ford and Honda are both very high volume car builders that employ components that provides some type of variation in timing or cylinder management or both. These small high output engines are here to stay and the car builders will simply have to work through their issues.
SuperDad
01-10-2019 07:18 AM
dexterslab724
2004 - 2008 F150
08-12-2017 12:51 PM
chamblizi
General Automotive Discussion
15
06-03-2012 04:18 AM
