I thought all Y blocks can use the same pump, at least if using electric wipers. I use the standard pump that an FE uses in my 292. With the integral fuel filter. Carter 4008 or 3528, I think it's Carter 6984, if filter not needed.
Airtex 4070. I carry a spare in case it goes out when I’m racing. Early 239’s had a straight arm on the pump, later Y’s had a bend in the arm. Dennis
thank you! That looks like the pump that’s currently on my truck going to order it from amazon.
the fuel filter I have just after the pump often looks like it only has a 1/4 inch of gas at the very bottom. Is that normal due to the low PSI or an issue?
i have one pre pump that is the one that only has a quarter inch of gas in it at times, the second is post pump before the carb. That is a metal canister so I can’t see what’s in there.
Mine has an air bubble in it, but it’s mostly full. I’ve run out of gas twice when it was very hot about 3/4’s of the way down the track. The pump will probably satisfy your needs. Dennis
